gas line leaking need help
Old Jun 30, 2009 | 09:18 PM
e320mb's Avatar
mercedes E320 1995
hello every1
i have 1995 E320 ... this morning i start the car and what i saw at the rear right end the car start leaking lots of fuel.i remove the shield where the fuel pump is... i saw after the fuel filter the ruber hose pipe which connect the matel then goes in the hood well where is the rubber hose pipe is connected is badly rusted... and gas is leaking can any one tell me if there is a way if i cut the pipe and repair?or i need to change complete pipe?if i buy a complete pipe how much will it cost?or if any one had same problem and fixed it plz give me the diy for that.
Old Jun 30, 2009 | 10:41 PM
JSe420's Avatar
1994 E420
cut the rusted metal fuel line back with pipe cutters. When you cut the rusted line, cut it back far enough so that you can use about 2 inches of good line. Once you have the rusted line in your hands cut the rusted part off...slip the 2 inches of pipe halfway in the rubber hose, put a new hose going from the 1 inch of pipe you have sticking out, to the metal fuel line going under your hood. Hose clamp it all up.
5 inches of rubber hose
3 hose clamps
About an $8 fix
Old Jun 30, 2009 | 11:11 PM
e320mb's Avatar
mercedes E320 1995
thanks alot i am posting the pic digram then you will know excatly what i am saying.
Thank you
3 hose clamps
About an $8 fix
Old Jun 30, 2009 | 11:26 PM
JSe420's Avatar
1994 E420
Ya sorry i forgot to add an important part...
Clamp off the rubber hose before doing any cutting. Your going to lose a little fuel no matter what.
Old Jun 30, 2009 | 11:48 PM
e320mb's Avatar
mercedes E320 1995
thanks alot for the help like to know something do you think that it can hold the pressure of the fuel?and if i want to cut down the matel pipe can you tell me with what should i cut it off?and on the rubber hose end there is matel part which connect to the matel pipe. should i cut that aswell?
Old Jul 6, 2009 | 04:22 AM
e320mb's Avatar
mercedes E320 1995
thx guys car is fixed now.thx for the help
