O.Z SUPERTURISMO GT ON W124!!!
i have a w124 230E and wish to put on O.Z superturismo GT alloy wheels but i fear that there will be scrubbing.Infact 17x8
and 17x7.5 and 17x7 are available.I do not know which one will best fit the w124!
Offset: 35mm
Backspacing: 5.71"
Bolt Pattern: 5-112
Rec. Tire Size: 215/45-17
Weight: 21.6lbs.
Help me please!!
thanks
Offset: 35mm
Backspacing: 5.71"
Bolt Pattern: 5-112
Weight: 21.6lbs.
Help me please!!
thanks
17x7.5
I run 17x7.5 et35 aero II monoblocks with 215x50x17 on a lowered Cab with no rubbing.
I've got the same size wheels with 225x45x17 and assorted other similar tire sizes on diff cars.
The 7.5 width and et35 is a very safe choice.
I'd really like to see those wheels on a 124.
Will a 8" cause rubbing even if it has not been lowered?
thanks,
steven
w 225x40x18 tires, no rubbing yet and I gave her a bit of a run.
I've ordered two 225x45x18s to try, since I favor a bit more rubber.
Hopefully, will run those all around.Of course, when the car is lowered, I might not get away with the taller sidewalls, but that's 2010 or later.
No one is talking +40et here, and if we are due to Carlsson using a different scale, it would be helpful to hear this 'splanation?
and a michelangelo
which one do u prefer and think will better fit a w124?
No one is talking +40et here, and if we are due to Carlsson using a different scale, it would be helpful to hear this 'splanation?]
Let me put it this way. The backspace of the wheel determines where the tire is centered on the wheel well. A 18x8.5 +40 would clear better than a 18x8 +35 because the +35 offset on 18x8 would be .5" closer to the fender.
Are you saying that if I find a set of Carlsson 18x8.5 et 40 to 42, that I could expect to bolt them up on a stock suspension car easily? Those go by now and then I think.
Mounted those et31 aero 1s on the black 380sl today. Nice hand me downs.
