Removing my springs repair bushings
Old Sep 20, 2009 | 07:16 AM
epowers777's Avatar
85 euro w124 300d non turbo black on black......coming soon hx35 turbo intercooler
This was the hardest and scariest thing I have ever done. The te 4 matic has quite the heavy duty spring. I had 2 spring compressors and had to strap my large jack to the bottom of the control arm. Then I removed the ball joint and left the brake and half shaft hanging on the shock. Everything went well until the spring compressor slipped next to the other on and bent the tar out one. Got to go back to harbor freight to get another one to get the bent one off.
Any ideas on an easier solution to taking the other one out.
Good thing Im cutting the spring so itll be easier to get back in. The question is how much cause Im doing it once only. I thing of doing a coil and a half.
Also repairing the bushing on the lower control arm anything special i should know.
Thanks in advance.
Old Sep 20, 2009 | 07:44 AM
ksing44's Avatar
2010 VW Golf TDI
I thought you couldn't lower a 4-matic.
Old Sep 20, 2009 | 04:23 PM
epowers777's Avatar
Yep you can
Old Sep 20, 2009 | 09:37 PM
pifcat2's Avatar
300TE / 300E / 300CE
You really should use the center Benz type spring compressor for safety! These are strong springs for typical compressors.
I was tempted to cut my rear springs since I have front Eibachs available but have decided on lowering all around with sport springs. People cut springs for the cost savings but shocks should be replaced and I believe you put them under more stress without the stronger shorter spring. Maybe the stock wagon springs are strong enough without a couple of coils, let me know how it works out.
Old Sep 20, 2009 | 09:46 PM
appatula's Avatar
95' AMG SeeThreeSix
Stay away from those cheap compressors, they don't work. If you don't use the MB specific compressor your better off just putting a jack under the control arm so its tensioned then once all of your arms are off (rears) just use another jack to jack the car up a bit and SLOWLY use the original jack under the control to lower it until the springs pop out. It sounds dangerous, and it is but I have done this front and rear over 3 times. I know you don't want to hear this but cutting your springs is the "poor mans" way out, it will achieve the look but not the performance of true lowering springs at high speeds. Make sure you do not use a high speed rotory cutting disk to cut them unless you have craploads of cutting oil to douse on it while you cut, taking the temper out will just compound an allready not so ideal situation. Just take a day and hacksaw your way through them.
Old Sep 21, 2009 | 03:06 AM
roach_juts's Avatar
2000 e430( w210),1979 240D (w123), 1992 300e(w124), 1990 mitsubishi galant VR4
i did cut my spring from my 300te wagon i think 9 coils left in the front spring & the rear i for got how many coils left ... performance wise its OK .. cant complain i even drive my wagon down hilling
Old Sep 21, 2009 | 05:53 AM
epowers777's Avatar
appatula Your the man thank you for sharing that with me Thats what I did and it worked great. I bought a second spring compressor and brok all them to get off the one bent one safely. It was a pain im gonna take both kits back to harbor freight and get my money back the ends popped off Dented my tool box!!
Ok how do you get them back on?
roach_juts How many coils did you cut? And how low is it do you have pics? Pls post!
I want looks not performance!! I already went threw my fast phase 600 buck ticket later I slowed down wanna cruise.
Old Sep 21, 2009 | 01:40 PM
roach_juts's Avatar
epowers i for got how many coils i cut ...
you can insert 1 finger in between the tire & fender for the front & rear
with a size 18 carlsson RS rims
with a 17 amg rims
Old Sep 21, 2009 | 03:04 PM
epowers777's Avatar
Thats exactly what i want Thanks. It looks really nice. I will count 9 coils and decide from there
Old Sep 22, 2009 | 05:05 AM
epowers777's Avatar
Well I cut about 2 coils. We cut 1 1/2 and bend down 1/2 coil.Will take pics. Was going to use a band saw but we smoked the blade. Big new piece of crap!!
Doing bushings tomorrow!!
Old Sep 22, 2009 | 09:47 AM
appatula's Avatar
95' AMG SeeThreeSix
Drive slow and with style then . Make sure you keep the coil cool! Even dump water on it after 10-20 seconds of cutting just to keep the de-tempering to a minimum.
Old Sep 22, 2009 | 01:17 PM
roach_juts's Avatar
i want to see the result.. cant wait HAHAHAHAHA
Old Sep 22, 2009 | 03:40 PM
epowers777's Avatar
Thats my goal slow with style no more tickets
Old Sep 26, 2009 | 02:10 AM
Ameen's Avatar
1991 300TE
Width and offset?? please!!
Old Sep 26, 2009 | 06:54 AM
epowers777's Avatar
Im pi$$ed I think I installed the wrong bushings for the control arm. The frint bushing is different than the back. The one I installed for the rear looks like the front. I thoght they were different cause they were a knock off brand. still shakes going down the road.Im just going to get 2 outa the junk yard. Waste of 70 bucks.
Cars not low enough might cut more coils off.
Old Sep 26, 2009 | 09:14 AM
appatula's Avatar
95' AMG SeeThreeSix
Yeah, front LCA (Lower control arm) bushings come in sets of two as the eccentric bolts on the front adjust the toe but more-so for camber alignment. The rears only have one bushing on the chassis end and its a lot cheaper than the front bushings. Sit back, relax, have a beer...you'll get it eventually .
Old Sep 26, 2009 | 04:42 PM
epowers777's Avatar
Do u know the part number forthe rear bushing on the lower control arm? its a 4 matic. 91300 te
Old Sep 26, 2009 | 07:20 PM
appatula's Avatar
95' AMG SeeThreeSix
http://www.autohausaz.com/search/pro...ber=2023520065
Not sure if the autohausaz part # coincides with the MB part number, but thats the rear control arm bushing (Inner). Hope that helps some .
Old Sep 27, 2009 | 04:33 AM
epowers777's Avatar
Im actually looking for the front control arm rear facing bushing. I ordered the front control arm front facing bushing. 2 to many. There different who would know So please help me find that one.
Old Sep 27, 2009 | 09:59 AM
appatula's Avatar
95' AMG SeeThreeSix
Sorry I completley missunderstood you. Strange, when I did my front control arm bushings they were both the same for the front and rear bushings per side .
Old Sep 27, 2009 | 01:00 PM
roach_juts's Avatar
front 235/40/18 et 38
read 245/40/18 et 38
minimal grind at the rear ... needs to shave the fender
Old Sep 28, 2009 | 05:11 AM
epowers777's Avatar
Went to the junk yard and got my spare springs. Got the bushing and will go in soon. got lots of sensors etc.
Old Oct 4, 2009 | 02:36 AM
pifcat2's Avatar
since the rear springs are tapered at each end, how do they fit after they are cut?
Old Oct 4, 2009 | 04:41 AM
epowers777's Avatar
I havent lowered the rear yet. I have to change the spheres.I am having issues withe the bushings. Heres the LINK for that
