going to replace spheres from autohauz
Old Sep 23, 2009 | 05:09 AM
epowers777's Avatar
85 euro w124 300d non turbo black on black......coming soon hx35 turbo intercooler
http://www.autohausaz.com/search/pro...ere/Air%20Cell
Question
Has anyone bought these and do the come with the copper washers?
In link below was suggested to buy washers sealsand pipes. Were do i get those.
https://mbworld.org/forums/e-class-w...mpics-pls.html
Old Sep 23, 2009 | 11:55 AM
ZedStyle's Avatar
Youngtimer
e-mal autohausaz and ask them, they are very helpful with info regarding the parts they sell.
Old Sep 24, 2009 | 07:13 AM
fred1948's Avatar
2005 E320 CDI
Question
I bought these about a year and a half ago for my 1995. They do not come with any washers. I have had good luck reusing copper washers by heating them with a torch to anneal them. Most auto parts stores stock a selection of copper washers as well.
Old Sep 24, 2009 | 11:31 AM
epowers777's Avatar
TY thats good to know. Did u have to get lines or anything or did u just put the spheres in? Pretty much what did u buy and do. I like knowing everything beforeI get into it
Old Sep 24, 2009 | 12:04 PM
fred1948's Avatar
2005 E320 CDI
I just bought the spheres.
It was difficult to get to some of the connections and get enough torque on them to loosen them. A set of flair nut wrenches will minimize your chances of rounding off the flats. The passenger side gave me the most trouble and I had to remove the 3 nuts that hold the sphere so that I could move it slightly to get access. Seems like I remember using small vise-grips on some of the fittings.
The spheres get removed from the inside, so you have to disassemble some of the interior to get the carpet up.
Try not to bend the tubing or it will be more difficult to get it to line up with the fittings when you install the new parts. Again, it is helpful to get the lines loosely fitted before you install the 3 nuts that hold the sphere (it may be screws instead of nuts).
Maybe someone will chime in with some tips to make the job easier.
Good luck.
