Tires question
I am currently running with 195/55/15 tires on all 4 of rims. It's time to change tires and I am thinking to put 195/55/15 front and 205/50/15 on rear....or should I just go 205/50/15 of all 4 of them?
My rims are oem.
Thanks.
I guess I will go with 205/65/15 then.....
I believe the oem rims are 15x6.5...and I wonder whether it's ok to go with 205/60/15.
If I check the tire fitment sticky, it shows that I should go with 205/65/15....
There is a little difference between these and 205/65/R15 (3%) but a great difference with your previous size; 195/55/R15 (-5%); which are smaller. But if you compare the 205/65/R15 with your previous, the difference is even great: 8% taller. Take it into account!
I should change 4 wheels to recommended size.
Ok, one more question here.
If I get 205/60/15, do I get more gap between tires and fender? I don't want to get more gap
but then 205/65/15 will be heavier than 195/55/15 so I don't want that either.
Right now the illusion of speed is really all you have as the smaller tires turn quicker and make the engine turn quicker, making the speedometer read higher than your actual speed.
