E-320 1995 no spark
Wires -> Rotor -> Cap -> Coil.
I'd personally check the coil first though so you don't have to take off the stuff to get to the rotor. I'd highly doubt the rotor is the problem though unless it completely broke off. My bets the coil if there is no spark. Usually a bad rotor will just cause the motor to run like crap.
Checked faults when it first stopped but they had never been cleared so there were many.
Horace
did any one unplug the alarm? it will also not crank if that happened...
Check fuses are rotate all of them in place as they are known to corrode even if they appear ok.
Check fuses including the OVP
just throughing out ideas....
bnztech04
1. OVP relay, located behind the battery.
2. Wiring harness shot, if it's still original.
