noob in need of wheel fitment help!
Old Oct 27, 2009 | 07:06 PM
cyertech707's Avatar
w124
will 18x8.5 and 18x10 et32 with 245/40ZR18 and 275/35ZR18 fit my 1993 300e? not lowered YET! please help! i found a good deal and want to get them asap as long as they fit. fender rolling is not a prob but if it needs more then that then i guess ill have to pass. Sorry for the noob question thanks all!!
Old Oct 27, 2009 | 09:44 PM
ps2cho's Avatar
E
No.
A) The fronts will hit the struts and stick out about 3inches over the wheelarch.
B) Rears will rub on dips in the road and almost certainly will be too wide.
Pass on them.
Old Oct 28, 2009 | 12:13 AM
w124
Originally Posted by ps2cho
No.
Pass on them.
what would be the perfect offset to run these widths?
Old Oct 28, 2009 | 02:31 AM
ZedStyle's Avatar
Youngtimer
i don't think an offset exists that would allow you to run a 10" wheel on your 300e.
also, there is a wheel fitment sticky that you should go through for future reference
Old Oct 28, 2009 | 02:35 AM
misabou's Avatar
E 220 Coupe E 320 Cabrio AMG E 300 Diesel
Probably 30 mm offset.
I know that 8.5 J x 17 H2 ET 30 with 245/45 ZR 17 was a size that AMG fitted in W124's. The front nearly touch struts (a little tolerance) but fenders need to be spaced and bent.
I don't know exactly for 18'' rims. I think 245/40 ZR 18 may be fit but 275/35 ZR18 not.
Old Oct 28, 2009 | 07:31 AM
Chappy's Avatar
AMG
Won't fit.....unless you're driving a 500E
Did the OP happen to see this?
https://mbworld.org/forums/e-class-w...-w124-pdf.html
