heater will not work any suggestions
Old Nov 19, 2009 | 05:31 PM
300eman's Avatar
1987 300e
Question heater will not work any suggestions
i have a 1987 300e no heat or air you can turn the temp wheel and it will click and bush the buttons and they will make a clicking sound thats all the fan will not come on how can i check the fan to see if it will work i have read one on page there is a wire next to the fuse box the only one i have is a plug for the power windows any suggestions thanks
Old Nov 20, 2009 | 12:50 PM
silversleeves's Avatar
1991, 300te 4matic
I am sure you have checked your fuses, how about your strip fuse? A new strip fuse might fix it for the short term, then try to find out why it blew.
Old Nov 20, 2009 | 02:33 PM
ps2cho's Avatar
E
http://en.wikipedia.org/wiki/Run-on_sentence
All serious...So the fan does not work at all? There is a separate fuse for the blower motor outside the fuse box. If all the fuses are fine, the regulator or the motor itself could be dead. Its semi-common and a somewhat big job to replace.
Old Nov 20, 2009 | 03:21 PM
300eman's Avatar
1987 300e
heater
yes all the fuses are ok ?
Old Nov 20, 2009 | 03:26 PM
300eman's Avatar
1987 300e
where is the regulator how do i check that ? thanks
Old Nov 21, 2009 | 06:20 AM
300eman's Avatar
1987 300e
Unhappy ho heat
thanks for your help but still no heat i guss i will have to take out the heater motor oh my back lol.
Old Nov 25, 2009 | 06:33 PM
300eman's Avatar
1987 300e
Smile no heat
i got heat thanks to all the great pic of the heater take out on here to that guy that made it you did a great job thank you
Old Nov 25, 2009 | 07:59 PM
ps2cho's Avatar
E
Any links to that thread? I'd love to add it to my FAQ links and I'm sure I will run into the problem sometime in the future...
Old Nov 26, 2009 | 08:02 AM
300eman's Avatar
1987 300e
Smile
here it is hope it workes just let me know http://www.peachparts.com/Wikka/W124BlowerMotor
Old Dec 2, 2009 | 01:31 AM
GORBETTTEAM's Avatar
'95 3.2 M104
Thumbs up
great post... thanks.
Old Jun 23, 2010 | 06:55 PM
Fitnessforyouto's Avatar
260e
I know this is an old post but my blower motor stopped working and I cant find the fuse on my 1988 260E does anyone know where outside the fuse box it is located?
Old Jun 23, 2010 | 08:28 PM
ps2cho's Avatar
E
It should be under a small black cover near the strut mount.
Old Jun 24, 2010 | 04:50 PM
260e
Thank you ps2cho, If there is power on both sides of that fuse does that go directly to the blower motor or then on to the switch inside? How can I troubleshoot the motor without taking it out?
Old Jun 29, 2010 | 08:11 AM
260e
No one has info on how to tell if the blower motor is good before taking it out of the car?
Old Jan 1, 2011 | 01:49 AM
jglover360's Avatar
1987 260E Base
260E Heater Problem!
Has anyone had this happen? My heater stop working all to gether like somone pulled the fuse out, no power to the controls, buttons, fan, nothing. The car will warm up and then a """Click""" sound under the dash will happen about 5 times then the heater may or may not come on. When it does come on, it works great, no problems. All fuses are good! Blower motor good! Core gets hot! I;m at a lose!!!! Please help?
