Found some things while doing Flex Disk!
Old Jan 9, 2010 | 10:51 PM
ps2cho's Avatar
E
This caught my eye...Lucky find! Maybe that will boost my mpg a little more since that vac hose was completely unplugged.
Managed to put it back on without having to pull the airflow assembly.
FYI to those who want to check them to make sure they are intact w/o removing CIS parts. Both of these vacuum hoses go to the Thermo Vacuum sensor on the head.
....Then I found a wasted engine mount...
Was going to do the rear diff fluid change, but I can't believe NOBODY around here carries a 14mm hex key I have to order it online now.
But successful flex disk replacement. I added the DIY to my thread up top.
Bad:
Good:
Old Jan 10, 2010 | 01:08 AM
JSe420's Avatar
1994 E420
Good stuff, is that a new tranny?
Old Jan 10, 2010 | 09:52 AM
appatula's Avatar
95' AMG SeeThreeSix
Sure looks bran new to me as well!
Old Jan 10, 2010 | 12:02 PM
ps2cho's Avatar
E
No, just clean from the crossmember and mount covering that. I'll let you guys know if I notice any improvement in fuel economy.
Old Jan 10, 2010 | 01:08 PM
ps2cho's Avatar
E
Managed to find Harbor Freight actually carries a 14mm hex! Dang lucky.
You know never know, it could be a new transmission, the car does shift damn perfect considering how poor the maintenance was...But the PO decided to not return my calls or send the history as she promised. I even offered to pay for the shipping
Old Jan 10, 2010 | 03:20 PM
pifcat2's Avatar
300TE / 300E / 300CE
what did you torque the disk bolts to, I did mine at 44 ft lbs.?
Old Jan 10, 2010 | 08:12 PM
ps2cho's Avatar
E
The hex key ones from tranny->disk are 40nm, the ones flex disk->propshaft are 60nm. Not sure what that is in ft/lbs. You should definitely get the E-Class owners bible, it has all the maintenance procedures /w pictures and all settings. Its a great book.
Look what else I got accomplished today!
Step 1: Find hole in exhaust
Step 2: Find can of sweetcorn (expired is preferred )
Step 3: Wrap said can around exhaust
Step 4: ???
Step 5: Profit!
Serious question though -- I changed the rear diff fluid and it was really clean, but it was a SEA BLUE color!? Does that indicate factory fluid or anything? Either way it was good to see the fluid looked fine Flushed and replaced it anyway of course.
Old Jan 10, 2010 | 10:11 PM
pifcat2's Avatar
I may have to get that. I have the Haynes, Brooklands, and a factory '86 manual but each has missing data.
Old Jan 10, 2010 | 11:50 PM
JSe420's Avatar
1994 E420
Step 4: ???
Step 5: Profit!
Serious question though -- I changed the rear diff fluid and it was really clean, but it was a SEA BLUE color!? Does that indicate factory fluid or anything? Either way it was good to see the fluid looked fine Flushed and replaced it anyway of course.[/quote]
lol sweet corn
are those zip ties man?? at least get some big hose clamps on there instead of the zip ties before they melt!
Old Jan 11, 2010 | 01:16 AM
ps2cho's Avatar
E
Step 4: ???
Step 5: Profit!
lol sweet corn
Yes there is some wire around it just used zip ties to hold it in placeso I could wire it up tight. I think the picture doesn't show it too well.
Old Jan 11, 2010 | 03:36 PM
JSe420's Avatar
1994 E420
Oh alright I gotchya
Old Jan 14, 2010 | 03:57 AM
BJaltima's Avatar
1993 400E, 1994 E420, 2000 SL500, 2014 C250
How long did the flex discs take?? What did it feel like when they went bad? Also, did it make any noise. Mine need to be done, but not immediately (so says my mb tech).
Old Jan 15, 2010 | 07:36 PM
pifcat2's Avatar
60nm = 44 ft lbs
40nm = 29.5 ft lbs
Good "ghetto" patch, I just paid a "hole in the wall" muffler shop to patch a hole for me since the large chains only replace...
