Help Flasher, Wiper and rear glass defroster problem
mercedes E320 1995
need help i have mercedes w124 E320 1995 since few days in my car the first switch of wiper and turn signal and rear defroster is not working.when i drive my car and go on bump or pot holes then the things work for 1 second then get off.so what i did i open the hood and i turn on the signal light and wiper switch and hit on the fuse box it work for 1 second then went off again.i checked all the fuse they were good.to me it look like under the fuse box there is a problem or it could be nutrel wire.plz can any one tell me what is the problem and can any one tell me how to remove the fuse box.
There is a multipurpose/combination relay that controls all three of those. Since you can hit the box and it functions that will 99% be the problem. You can either A) Resolder it B) Get one from a junkyard/buy a new one online.
It is the longer relay of the (2?).You'll see it when you unscrew the main cover.
mercedes E320 1995
wiper washer problem
hi i open the box and the long relay works when i move it left or right so what i did i took thick papper i put between the to relay now its working but the wiper washer is not working.do you think the problem from relay?
Been browsing these forums since I bought my grandfather's 94 E320 in November (67k miles) and I'm having pretty much the same issue, with the exception that it's not limited to the wiper - my power seats no longer work, and my rear defrost button makes a weird buzzing noise when I try to turn it on.
My friend and I took out the culprit relay last night and resoldered some of the circuits inside but still no go - didn't see anything that looked physically damaged (my friend is good with electronics/cars so I trust his judgment.) Should I go ahead and order the part, or is there a possibility it could be something else? Also, there was a reference here about the larger of the two relays being the one to check, but according to another thread I thought it was the smaller of the black ones? (The labeling actually mentions the wiper and rear windshield if I remember right.)
My main concern here is that with the 4-6 inches of snow we're getting today I simply cannot drive the car - I'm actually working from home today.
mercedes E320 1995
i checked the small realy is a problem well i opend it and check coudnt find any thing lose so i am sure need to be resplder but i cant find which one need to be.so what i did i took a thick papper fold it and put on the top of the small relay and i closed the box so the fuse was pressed hardly .now everything work but i know i have done temperly work.anyway i will get that part when i get free time from scrapyard.
Thanks for the help guys.
