C36 TURBO
The 3. 6 Is finally for sAle. $29,750 OBO
Body: 1996 C36 Amg. 73,032 miles
Suspension:[/u]Full upgraded suspension.
1 1/2 lowering springs with bilstine shocks, custom rear camber and caster arms. New front control arms and wheel bearing.
Brakes : C55 brakes and steel braided lines (all R. P fluid).
Engine: New engine block with special fitted spacers,
CP pistons and Cunningham rods . Custom rod and crank bearings ( compression drop, secret specs ). Crankshaft lightened and balance. Cylinder head ported and polished with added collant ports. Custom high pressure oil pump. custom 3 layer metal head gasket.dual core radiator sized to fit
Turbo: T67 turbonetics turbo S trim, water and oil cooled. Custom turbo short runner manifold with tial 38mm wastegate,Full stainless steel exhaust system and electronic muffler bypass ( boost controled). Custom Bell.Inc air to water ( top mount) intercooler with fully independent radiator and cooling fan ( fully adjustable temp setting)
Transmission: Rebuilt 722.3 transmission with all v12 internals, independent trans cooling system with radiator and fan (adjustable temp control).
Electronics: Haltech E11V2 engine managment system. Greedy boost controler. Msd Knock alert system. Haltech A/F gauge with heated O2 sensor. Defi electronic boost gauge.Dual crank sensor system with msd signal converters.
Methanol injection kit.
Interior: C43 adjustable bucket seats. Upgraded sound system. Sunroof shade amg cover.
Note: all factory systems still work. Traction control, cruise control, washer systems , abs and all obd 2 systems.
CAR was tuned by Ivey tune and dyno at 459 whp @ 16 psi. 399 torque On the conservative side. Engine and trans has 5400 mi. Turbo can assist up to 25 ps
E55 market is very soft..
Guy doing my widebody conversion just picked up an 05 or 06 with 38K miles Merc CPO for $30K....with 1.99% 66 month Merc financing...
Lot of deals out there for newer AMG, that's why I snapped up a Black Series !
I knew you were ballin' out of control!
But I agree with you! When I was in the market, I found some as low as 16K coming out of Manheim. Ridiculous!
The BS was owned by Sabates racing team partner, Chip Ganassi ( Target Racing..Indy, Nascar.. )
I'll post pix as soon as it arrives...
You and Zorro will like it Black with black interior...
I would have preferred Red or white ..but couldn't resist the deal..
At Barrett Jackson in Phoenix, Aaron Rubin sold his C124 Hammer for $32K+ and his S124 Hammer for $42K+
The wagon was purchased by Jono in Atlanta...
The turbo C36 isn't anything correct or special....
Amazed Aaron got that much for those cars. Didn't you bid something like that on his sedan?
