Next Stupid Stereo Question
Now Most of the speakers don't appear to work, but when I turn on the car, and fire up the stereo and disconnect the harness to the amplifier, I can still hear the front right speaker (tweeter?)... The left channel is not operational. Are the front speakers tied to the headunit? Trying to figure out whether or not to replace the head and amp or other. The stereo is very sick right now...
Can I swap the head unit out with an aftermarket unit and not worry about goofy signaling from the H/U to the Amp?
ALso, is there a good place to find an OEM unit if I decide to just drop an OEM in?
or find an Ebay one, or li swapped a stock one form a junk yard.
If you want OEM feel, but udated CD Becker makes a replacement single CD one also.
Good luck
I have a schematic, I just need to find it and I'll repost it in high res.
I decided to live with it until I can pull everything and start from scratch.
A tumbler is part of a lock mechanism.
i didn't have a wiring diagram or a voltmemter so it was pretty tedious trying to bypass the amp, but it was definitely doable with a little patience
I decided to live with it until I can pull everything and start from scratch.Ah, I'v got a whole different answer for you now... Just go down to Radio Shack and get a can of Tv/Control Cleaner & Lube for $10.99.
http://www.radioshack.com/product/in...ductId=2103700
Remove fuse to radio, remove volume knob and spray this in the hole, replace knob and move it left and right both fast and slow for about 2 minutes. Let evaporate for 10 minutes and replace knob and then the fuse.
You should be good as new!
THe replacement H/U that I got off of ebay is in much better shape , but 3 out of 4 channels are still down. I am thinking of replacing the speakers...Does anyone have a size guide?
Again, I have a 1994 E320 Wagon.
PS, I also think I found the CD Changer hookup in the trunk...Pretty cool.
Only drop in replacements are Rainbow IQ series made in Germany. About $320 for the set of four speakers. OR pick up some clean oem from the junk yard for much, much less.
Seems like you only need one speaker, I'd grab a clean oem and smile
Did you try cleaning the volume/power knob on your old deck? If you do and it works like it should sell it to cover some of the cost of the Rainbows.
