Magnaflow high-flow cats for 500E?
I would run a "Y-pipe" between the new cats and the existing Lorinser muffler.
Anybody purchase this product?
http://www.hottexhaust.com/detail.asp?PRODUCT_ID=59926
Price looks great.
Is there a slight performance increase?
How does it sound with resonator removed?
OE exhaust withresonator and Lorinser muffler, is very quiet.
Price looks great.
Knock off of the much higher priced Random Technology design.
By replacing an SL55 cat with two Magnaflow units I gained 11HP on the dyno.
Not to mention that I "rattled" the SL55 unit while dyno tuning.
This was on a twin turbo application where less back pressure creates more power...
Should give similar results on a NA engine.
You have heard my car, so you know what this setup sounds like, yours would be similar but much of the tone will be due to the rear muffler your using.
I wondered what people thought of the Magnaflows themselves - obviously, all good!
Ed: Your experience sounds very positive. I guess I can expect 0 to marginal increase in HP, starting with less base hp than boosted SL55.
Rik: Very much liked the sound of your setup in January. Quiet at idle, yet screamin' on acceleration.
Is that the same as two years ago? I didn't think it was as loud at that time.
I didn't see the 2 into 1 unit, but I'll look again.
Did you have to special order the 3" pipe out the back? I expect my Lorinser is only 2.5" anyway - same as stock?
I appreciate the help - off to the bodyshop first, though!
Does your 500E have precats? I removed them from mine (for some reason the '88 300E had 2 precats, but I've never seen any other 103 or 104 engine with precats) and mostly what you get is more sound.
No pre-cats.
I want to scare off Hondas and minor Bimmers, but NOT my neighbours.
I think that if Rik's car is anything to go by, this combo will be perfect.
When I saw the price of the Magna cats, I was concerned about quality, but so far everyone here seems really happy.
No pre-cats.
There are several routes you could go, dual cats like the OE design or the two into one (like mine) Magnaflow recommened the latter.
3" pipe is probably too large, the 2.75" pipe would be easier for your shop to work with anyway.
The final sound will depend much upon the rear muffler you choose, I suspect that if you keep the Lorinser muffler, your final tone will be less dramatic than mine.
Oh and yes, my exhaust setup has been in place for at least four years now.
On my youtube channel, I have some audio of the exhaust sound
http://www.youtube.com/watch?v=3dWOBYbEGq0
I plan on keeping the Lorinser muffler, you see very few on these cars in recent years.
Magnaflow showed nothing when I searched 500E, and no 2 into 1 cat when I searched 5litre Mustang.
However, I'm sure something will work. I sent a query to them directly for the 2 into 1 application and suggestions. I'll see what they have to say.
Besides, though I appreciate all your inspiration, I shouldn't copy your car directly, I suppose
I'll let you know what they say.
one more question, though - what are the stock diameters of the pipes on either end of the OE cats???
