Steering wheel making "creaking" noise
Old Apr 15, 2010 | 12:30 AM
ps2cho's Avatar
E
It started when I switched to the 500E/Sportline wheel....The bolt is torqued to the correct 80nm. I replaced the bolt today thinking maybe it was just tired, but still no luck. It makes a creaking noise on turning.
Any ideas?
Old Apr 15, 2010 | 01:13 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
The wheel rubbing against anything? Or perhaps the horn contact ring?
Old Apr 15, 2010 | 09:25 AM
latief's Avatar
1993 300e 2.8 - M104 Engine, SOLD; S320 2000
Ball-joint! that was what mine did before i needed to change them...spray some silicon grease in there and see if it goes away.....
Old Apr 15, 2010 | 11:47 AM
ps2cho's Avatar
E
Where is this ball joint on the steering column??
Old Apr 15, 2010 | 12:44 PM
latief's Avatar
never-mind, thought the front suspension was making the creak noise...my bad
Old Apr 15, 2010 | 01:04 PM
ps2cho's Avatar
E
Had a feeling you made a mistake...
Old Apr 22, 2010 | 10:58 AM
ps2cho's Avatar
E
Anyone else?
It feels like I can move it more than I would think is normal. Maybe that is the creak...simply slack?
Did the updated wheels require a bigger torque setting? Maybe 80nm isn't enough?
Old Apr 22, 2010 | 11:53 PM
ocpanther's Avatar
1989 300E
If it can move more than previously, I would bet there is a spacer/washer that was a slightly different thickness on the newer one. If you increase the torque it will just bind the bearings more.
Did you check the horn contact ring or the plastic/backing? I wouldn't be supprised if the backer plastic (or whatever material it is) was warped slightly different from your old one.
Old Apr 23, 2010 | 11:30 PM
Quicksilver500's Avatar
1992 Mercedes-Benz 500E
I had the same problem, not so much a creak and like a swishing sound while turning. Haven't diagnosed it yet, but a buddy has a wagon with original wheel and it does the same thing! Radio fixes it so far
-Mike
Old Apr 24, 2010 | 01:48 AM
ps2cho's Avatar
E
-Mike
I believe it also makes a swishing sound...
Radio cures for me too, but I want to get it figured out soon. Not high on my priority list yet. Just wondered if there was an easy solution.
