To lower or not to lower?
1) Use MB sportline springs which would lower it about an inch and not affect the camber or my insurance.
2) Use aftermarket lowering springs which are cheaper and lower by 2". Is it then okay to use the original shocks? Would I then need a camber correction kit?
3) Use a Bilstein Streetline kit. - 2" drop and new shocks.
4) Use the aftermarket springs and Bilstein Sprintline shocks.
I favour the second option because it's the cheapest!
Any thoughts?
I have already put Bilstein HD Shocks on my car. What would be the best springs to use with my shocks?
I too am tempted to simply put in springs then get shocks when I can afford them. If I had the money I would go with the sportline package (springs/shocks/bushings). Though the article on MBZshop showed little in the way of drop (springs and shocks can take time to "settle"), I believe that you'd really see around 1" drop.
Not sure about the whole camber issue.
Also check out Mercedesshop.com and do some searches under springs -
This link might shed some light (it is about springs for M119/W124s but good info nonetheless) -
http://www.mercedesshop.com/shopforu...w124+sportline
I droped my car with eibach pro kit springs (which are the only springs eibach offers for the 1985-1995 yrs) and bilstein sport suspension. And it is almost stock height still. (also number 1 pads in front and 2 pads in back). Wierd i know.
One thing i noticed is that when I droped two W202's with H&R springs, both ended up with different heights. I believe thats why MB use's spring pads to adjust that difference between all cars.
MY ADVICE: is go with H&R springs. They say H&R are stiffer then the eibachs but i think they both feel the same. I think H&R's give a better drop then the eibachs as well.
If you are worried about comfort then leave your suspension alone.
sold-
ps: nice coupe!
I got really excited about changing the pads but I just looked underneath and found I have #2 pads on the rear and #1 pads on the front. I guess that's the end of that.
My last car was a 300E-24 sportline and it was definitely lower. It was noticeably so when parked next to a standard car.
I hear what you ksing44 (1" drop = K-MAC). I'm using 235x40 tyres so I guess if I lower it without the camber kit I'll eat them in no time.
I think I'll leave it alone until I pluck up enough courage (cash!) to buy shocks, springs, K-Mac bushes and sporty swaybar all in one go.
BTW, pkmaven, are you sure the coupe "comes with a tighter suspension"? Looking at the part numbers the saloon and coupe use the same suspension parts.
I will give you a bit more information about my experience just in case it helps you if you decide to get the mods. I started with #3 pads all around when stock and then switched everything to #1 pads when I had the Eibach Pro-Kit springs and Bilstein HD shocks installed. I then switched back to #3 pads in the rear because the rear dropped a lot more than the front on my 1995 E320 SE. I added the K-MAC bushings when I increased the rear spring pads because my camber was almost -3 and it could not be adjusted without the new bushings. The camber is now adustable to within specifications. In terms of the gap, I still seem to have a little difference between the driver side and the passenger side. Now that the gap is smaller, even small differences are noticeable. The driver side is exactly the same gap front and rear, but the rear passenger side could come down a little. I am also not sure how my own bodyweight affects the ride height and gaps. Maybe when I am in the car, the driver and passenger sides are the same. I am thinking about switching the rear pads one more time to #2 in the rear but I don’t like the car to look like it is hauling heavy weight in the trunk. To me, if it is too low in the rear it looks like your car is old with a broken down suspension. I am constantly looking at the car, measuring, and wondering if I should try #2 pads. I am getting a little crazy I guess.
Other notes: I guess I should have gotten Bilstein Sports, but it seems OK with the HDs and the drop really is pretty minimal. Here is where I was wondering about the European ride height. If the cars are lower in Europe, then HDs may be fine, because the minimal drop in US height may actually have the car at the European height. In this case the Bilstein HDs wouldn’t really be on a car that was dropped. This may be wishful thinking on my part, but I am not planning to run out and get new sport shocks right now. The HDs are guaranteed for life and the valving is just about the same as the Sports.
I really am quite satisfied with the car right now. It is firm but not too stiff and it handles amazingly well. It is truly a "sport sedan", not just a highway cruiser. Twisting back roads are a pleasure to navigate and I don’t feel I have lost too much of the comfort that our cars are known for. It is just rock solid in every situation.
I don’t think you will be disappointed if you drop your car a little with a firmer spring and shock combo. You will have real "sport sedan" that can hold its own on a twisting back road. It may take some trial and error, however, to get it just the way you want it. If I did it again, I think I would get H&R springs, Bilstein Sports, K-MAC bushings, start with #1 pads all around, and then figure I might have to adjust the pads to get everything just right. I don’t think I would get the Sportline mods, because it doesn’t look like it actually lowers the car very much and I think the stock height is way too high. I would really miss that hunkered down look. Mine is only an inch lower, but to me, it looks much better. In terms of handling, I doubt the Sportline can out maneuver me on a backroad.
Check out the pics in my sig as well...
