Looking for a W124 Wood Steering Wheel
1993 300CE CONVERTIBLE, 1999 S500
Black Color, with Burlwood. Wood must not be cracked. Let me know if you have one. Steering wheel has to be from a car that is before 1993 because the wiring is different.
500E Signal Rot
92-93 used the same contact ring, no difference in these years. 86-91 used difference wheel/airbag/contact ring, but you can upgrade those wheels with later model wheels (92-99) very easily.
I had a nice burlwood steering wheel from 1996 E320 and tried putting it on my 300ce, it did not work at all, my mechanic said he tried everything but it did not work, even he tried switching the clockspring. He said something that positive and negative are in different places.
I know this isn't the question...but it looks like a real nice 390mm sportline/500 steering wheel on ebay item 190391416450 (don't know seller, but feedback looks good)
500E Signal Rot
How can I upgrade to 92-99?
Visit my site at www.2phast.com/500e and go under the interior section. I detail in great length the installation of a 1999 E55 steering wheel on my 1993 500e.
500E Signal Rot
Oh, really no difference between a 95 or a 96 wheel. The clock spring design changed in 1994, so from 94 to 99, the wheels were more or less the same.
1996 E320 Sportline Cabriolet x 2
Doubt it, last year for the W124 was 1995, unless you live in India or one of those few countries where the W124 was carried over for a extra year.
A 1996 wheel/airbag will fit a 1993 model by installing the clockspring from your 1993 steering wheel. I don't know what your mechanic tried, but chances are he has never done a swap like this before.
500E Signal Rot
As per my site, with the 96 wheel, you need to remove the black plastic filler piece to install the clock spring.
Depending upon the type of airbag you use, you may need to do some interior wiring (most notable with the SLK/CLK type airbags that have two horn buttons). The regular airbags (like your 93 has) does not need any additional wiring.
So on the 96 wheel, this plastic ring needs to be removed.
![](http://2phast.com/500e/e55-11.jpg)
The horn contact ring assembly can now be pressure fit into the wheel
![](http://2phast.com/500e/e55-12.jpg)
This is what the 92-93 clockspring looks like installed on a 94+ steering wheel. The 94+ wheel has an extra hole in it, this is not used when you install the 92-93 contact ring. Also notice the wires, there are two, these complete the horn circuit and are connected to either side of you horn/airbag assembly. Your wheel would look a bit different inside then this picture though. Both of these wires need to be hooked up to complete the horn circuit, otherwise your horn would not work. This is most likely where your mechanic had problems.
![](http://2phast.com/500e/e55-16.jpg)
Yes thats what he had problems with, the wiring. Thank you so much for your help, now I have more choices of the steering wheels to chose from.
thanks a lot
thanks a lot
