Suggestions on Transmission and Engine Rebuild ?
The M104 engine needs a headgasket desperately. 1 quart every 5 tanks...I think all is leaking not burning.
I am going to look at the bottom end bearings and replace if necessary. Not sure about the rings... should I bother?
Suggestions on rebuild kits out there?
Any specialty tools I will need to rebuild?
Other parts I should replace for sake of ease while I am cracking it open?
Any fun bits worth doing since it is apart...cam..power pullies?
I have rebuild an engine before...though never had to time a DOHC.
Any decent pdf manuals I should download?
The transmission will most likely get a full rebuild while it is out. I figure if I don't do this then I will never have a reason to rebuild a transmission ever and never learn how.
The game plan after lots of deliberating and thinking of buying a used engine/tranny, or just a used tranny, or even a whole car to part out and keep engine and transmission has yielded to just pulling the existing ones and rebuilding both.
Thanks for any help... I have been reading up as much as I can but have little free time these days to do proper research on my own.
There is no reason to look at the bearings or rings in vast majority of cases.
You should replace the valve stem seals and have the head machined. Replacing the short water pump hose would also be smart.
Regarding the transmission, it´s also a straight forward job, if you´re familiar with those things. Some special tools and a bit of know how required. Number one being cleanliness.
Cheers,
No reverse is the B3 disks. Search my name and you'll find my thread on it. Lots of pics. It happens to every 722.3 at some point so don't feel bad.
I am going to do all the clutches since I intend on keeping the car for a long time.
I am still having trouble finding a comprehensive post on parts needed in an engine rebuild. Any suggestions where to look? I have checked MB world and peachparts. My intention is to drive this till at least 300k and would hate to have to pull the engine a second time in a few years.
I haven't read of oil pump failures yet, so I guess I'll leave the original oil pump. Other than Hoses, gaskets and belt and chain tensioners anything else I should be ordering for the build?
I still can't believe I was reading this thread when my wife called and said she couldn't back up the driveway......what are the chances?
J. M. van Swaay
http://www.ps2cho.net/downloads/phot...722_repair.pdf
http://www.ps2cho.net/downloads/phot...n%20repair.pdf
I'm in the process of pre-project evaluation. Any guesses as to how many hours I should figure for tranny remove/reinstall, and for rebuild once it's out? I'm a pretty capable DIY'er, couple of engine rebuilds, but never a tranny. I might just remove it, and then take it to a shop for rebuild. On the other hand, I hate to pass on the opportunity to learn something new.
Thanks again for the PDF's
J. M. van Swaay
Dead clutch and trashed two steels. I think the clutch failure somehow trashed the the spring retainer and destroyed the springs too.
my B3 clutches are dead too.
I think the K1 was serviced before (poorly) as there were some missing parts (shims and washers) on some of the pistons. also one of the pistons was installed backwards.
I have a full rebuild kit that included all the clutches, seals and gaskets. I need to find the steels I need, as well as the spring retainer and springs. I have gouges on LB 3 but I think I can just debur and re use.
Any idea what this part is? I have no reference in the manual and it was on my work table when I removed the valve body.
Disassembly was easier than expected. I pulled the motor and tranny out together. Took about 5 hours or so.
I hope you realize you MUST do a complete rebuild of every component since you don't know what could have made its way back...
Told you dis-assembly wasn't too bad
That orange spring came out of the valve body?
If you want to re-use the b3 disks, get some sandpaper and rough em up as they are pretty scored in comparison to mine.
Cheers,
J. M. van Swaay
The disassembly is as easy as ps2cho stated. I think you should go it yourself and learn a new skill. I used the 722 repair pdf and it is very comprehensive so far. the tricky one is removing the B1(??the one on the passenger side front). We used the oil fitting to the radiator with a custom pry bar that i had fabricated to compress valves. Any stable pry bar will work. I recommend 2 people for this step. I will take picks on re assembly to better show the process.
http://www.partsgeek.com/gbproducts/...ek+Google+Base
It looks complete, and is by far the cheapest I have seen that is complete. (no filter though). I will know more once I re assemble and let everyone know here if there is anything missing. So far i need some K1 Steels due to the wear, some springs and retainer. I am going to look for used ones.
If it is slipping definitely rebuild soon, that way you only need to replace seals and clutches. If metal gets around you may have more issues. I haven't found anything too traumatizing yet.
I have a little concern as the PO told me he had the transmission recently redone. All but the k2 clutches were worn. There was also a pin that was installed backwards in one of the pistons. Some of the seals look newer and some are rock hard. It was seeping from the rear cover, the rear output shaft seal and a couple of the piston seals. all minor, but if you are refreshing your trans wouldn't this get redone? the wagon has 175kmiles now and this will be the second major trans service. I am wondering if the mileage is higher than stated when I bought this about a year and a half ago.
Cheers,
