WTB: Strut Brace
Thanks in advance,
- FD
Thanks in advance,
- FD
About ten+ of us have strut braces on order that are being custom made.
Not sure if a strut brace will help you..
Obvious that you have something seriously wrong if you realize cowl shake.
I have a 94 A124 and it is as solid as my 1988 C124.
Do you have the dampener installed on top of your shock tower ?
Ed A.
Thanks, I will search that.
The cowl shake I'm referring to is bump related not speed related. As with any convertible the body just doesn't have as much torsional rigidity, so there is some body flex over bumps. My SL also has a bit of this too, and in fact, the e320 is actually a little tighter than the SL is with the hard top off. I just wanted to see if I could reduce it further.
The rubber anti-vibration damper is in place and the rubber "spider" is in tact. The wheels/tires are new & balanced.
If you are up over 100,000 miles I would be looking at suspension components to reduce the wobble AND possibly a more compliant tyre - this is from first hand experience. Green car is on P6's, Blue is on Conti Comfort Contact-1's, standard sizes for Sportline cars. Bog standard cars the pair of them, RHD so not even a vibration damper on the suspension turret.
- FD
- FD
Only one that I know that makes the bar is Weichers in Germany, but not sure if they make for the cab.
The strut brace will stiffen the engine bay / chassis laterally.
The vibration dampener is "tuned" to isolate at a certain frequency.
What is the condition of your struts and strut mounts along with all the rubber bushes in the front suspension?
As I earlier posted I have zero "cowl shake" in my 45K mile 1994 A124...every bit as solid as my 67K mile 1988 C124.
Ed A.
I am replacing the struts/strut mounts prophylacticaly - in fact I'm trying to confirm the Bilstein HD strut part numbers on another thread. I have checked all the other tie-points (ball joints, bushings, etc) and they are in good shape.
I agree about the vibration dampener being a tuned device, which is why I mentioned that this is not a speed issue. The reason I thought a brace might eliminate it is because the brace will change (lower) the characteristic frequency of the chassis, perhaps to the point where the vibration (resonance) that the damper is supposed to counter does not occur or does not occur at normal driving speeds (the factory resonance seems to be at about 60 - 65 MPH).
Getting back to the torsional rigidity, the way you can really feel what I'm talking about is to put the palm of your hand on the upper corner of the windshield / A pillar and your elbow on the top of the door while driving with the top down. Effectively your arm is forming the side of a triangle. When you go over a bump you can feel the flex in the frame because the side of that "triangle" formed by your arm gets shorter/longer as the body twists.
Anyway, It was thought, but it looks like a brace may be much more trouble than it's worth.
I will post what happens with the strut change. The reason I'm going with the Bilstein HD's is because I think the additional un-sprung weight of the monblocks is hard for the OEM "comfort" struts to control.
Thanks,
- FD
Sparco makes one and had only one in stock in their California warehouse....
Arrived yesterday !!!
Listing starts on page 7 of the below old price list
http://www.sparcousa.com/2003_USA_Price_List.pdf
Give them a call at 1-800-224-7223.
I spoke to "Allen" who confirmed part number as 03694.
They had one in stock.
Ordered it through OG Racing in Sterling VA ( Brian 1-800-934-9112 ) who was recommended by Sparco as their largest East Coast distributor.
Price was $299.00 delivered, polished aluminum, adjustable and weighs about 5LBS.
Will try to fit it soon and see if the outer firewall/bulkhead has to be notched.
I would think if it is catalogued they will make to order if there is no available inventory.
Ed
- FD
My theory is that the vibration absorber is a kludge, added to deal with a chassis resonance that popped up as a result of the "chop" operation for converting a coupe to a cabriolet. Anything that changes the fundamental frequencies of the chassis has the potential to eliminate (or to worsen) the resonance that required the "fix" in the first place. I would not be surprised if MB evaluated various bracing options before deciding that the damper was an easier (cheaper?) solution.
BTW, I just got back from Europe where many a W124 wagon is still doing taxi duty.
- FD
[IMG]
[/IMG]
