(89 300ce) Why did 80% of my dashboard gauges stopped working?
My tachometer, gas, temp and oil pressure gauges all stopped working a couple of days ago although my speedometer, clock and economy meter are still working. Since the group of gauges went out at the same I figured it had to be a common fuse or relay. I checked all the fuses and they look fine so it must be a relay – right???
If anyone has any experience with this, I could really use the help. Thanks
92 500e, 95 E34 525I Touring
There are fuses on the back of the cluster itself. They look like little buttons:
![](https://farm4.static.flickr.com/3019/2908748958_068de26584_o.jpg)
![](https://farm4.static.flickr.com/3177/2908748950_26dcc245dd_o.jpg)
The red one does instrument lights, but there may be more that control other cluster functions. Just a thought.
94 E320 Wagon, 89 300SE, 86 300 SDL
Dash Guages
I had the same problem and after much trial and error I took the cluster out, lifted out thefabric under the cluster and saw two ground posts.
I created two grounds on the cluster, one from each side of the guages and wired them to a ground. All guages worked fine from then on. This is over one year.
Hope this helps, check fuses first as rivcal says.
Good luck
John
Good luck
John
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
The gauge cluster has 3 parts and they all have a common ground that you can trace between them. When the pods are apart from the cluster look for a - mark and the rest is easy. I put one ground wire at each end and my gauges work great.
Let me know how things work out
John
John
1989 300E 105,000 miles
Grounds
I had a similiar issue. It was my oil pressure gauge, clock and tach. I hooked up a ground off the back of the cluster near the clock to a nut near the steering column! No problems since!
1993 300e 2.8 - M104 Engine, SOLD; S320 2000
fuse 5 or 6 will take out half of the cluster. happened on my car and on a friends car...check your fuses before doing anything else....
good luck
good luck
