300E Turbo LPG Project
Also, they're going to luv me for pouring oil all over the rocker gear/valves prior to turning engine by hand @ my place
I'm positive I got oil down the valves & definitely squirted oil down each spark plug hole
Um, I will have to warn them
So, here comes the fun! When it gets home from shop this time round, I need to replace shocks/springs/front brakes. Install sound system just for starters. I will pop pics up for all this home stuff. Also, pics when car gets home after the engine bay work of course
EDIT: It will be very interesting, on the pocket too, as to how the hell the workshop will re rout throttle & kick-down cables to reach the front of the boxy plenum as this is where the LPG mixer now sits. Looks like they will be making up a divider, perhaps a bracket of sorts positioned @ the rear of the plenum where cables will unite & then subdivide to join other section of cables then heading down to throttle body/mixer
Then they will have to fabricate an enclosure box for the pod filter I guess?Indeed will be interesting............
Was pondering the expense of needing entire new stock exhaust system from headers to tail this morning & on the gutless performance the car will be coming home with as an N/A on LPG when I had this brainstorm......"boost the thing now or go to hell"
so, spoke with shop this morning who added the custom boxy would be horrible to tune as an N/A so, I said "er.......let's boost t now & get it over with already He starts the LPG set up today & will discuss the fabrication of the steam pipe turbo header with his guy this week. I also have to take all the turbo & gear over there later in wek so he has it all ready to go.
FINALLY someone gives a crap about the 300E
& there's no turning back, Jack!!!!!!!!
get a regular mbc. I got a forge unos mbc. very precise and works great!
I mean, some cars with MAFs (or was it MAPS, I keep forgetting) allow you a certain amount of boost before the ECU ceases to comply. The Toyota 2JZ comes to mind.
Or the second option is to add additional fuel injectors that can be tuned via a laptop. This way you can have some sort of tuning so the additional injectors compensate where the cis system fails to supply enough fuel
EDIT: a member from another forum sent me a link to US dealer for the WG. Prices are great so will be looking into this today. Tial BOV is about the same $$'s though but if packed together will save freight.
Concerning the boost controllers, I can run an APEXI, or the like ebc as they have their own computer to control boost but they are too expensive for my liking...............
Also, looki looki into a way around the turbine housing dilemma I am faced with namely, whether to go with current .63 A/R or swap it out for the .82? sooooo, me thinki thinki.....a while back I mentioned I was researching into twin scroll turbine housings & went hard down this road for a bit but decided against it due to extra cost to swap over as it needed to be sourced from US for my custom turbo. Well, turns out I may just pick the banner up again Why? It will solve the housing dilemma
I have my turbo manufacturer getting back to me in an hr or so with availability of a .82 A/R twin scroll T3 housing to suit the turbo & may be here in Aus
This way the header fabrication won't be held up as they can use the T3 footprint & swap out later even = much goodness
This is a really important mod for me & will ensure the car will be more competitive on the street hehe. Will report back with how it goes soon. Kinda running outta time with preparations now. Shop needs to get moving along..........
Concerning ignition, we're having alot of hassle trying to work out the MSD set up that was originally on car. Real pita!!!!!!! Just can't see how the car originally got spark with this set up? Even a Merc guy we consulted states we need the original distributor but it's on dedicated LPG via a mixer damn it
So effectively, we're stumped until we work this part out Either we source a trigger wheel here or we may go Haltech with wasted spark? This is what I'd rather do so we can get moving on it. Trying to work with this MSD is holding the whole thing up............
if you had msd efi, a regular boosted M103 would do an easy 300-350 bhp on stock internals!
According to my months of research on the subject, a better headgasket with a slight compression drop and heavy duty head bolts and it should take you past 500 reliably. But then you're chassis will start to crack in two if you take it road racing.
400 bhp seems to be the sweet spot.
Shoomakan, the M103 & M104 bottom ends are the same really. The M103 head is prolly stronger & better for boosting going off Romans' (PUMPISH) recommendations although, would certainly like the piston oil squirters from the M104 block
Yes the head gaskets, as with the rings, are the weakest links but I think my engine's an 89' or 91'? so hopefully it had the better HG than the early ones? It's not so much the hp I'm worried about rather, as chlippo suggests, the fact I'm on my own with the LPG set up. But @ least it's in the best workshop around for getting this kind of set up right
so it seems the amg 103 engine was built very well indeed.
I'm hoping up ahead to measure an aussie XR6T LSD to see if it will be a fairly simple fit?
