300e Engine/Transmission removal ?'s
Old Sep 17, 2010 | 08:31 AM
garrettt3's Avatar
1992 300E 4-Matic
Hi all. I have removed a few motors on cars before and now I got a 92 300e 4matic (blown motor) that i need to pull out and put in a replacement I have. I also need to get the tranmission out thats in it for B3 problems. (Dosnt go into reverse untill warmed up) I have the owners bible but it dosnt have anything on engine removal.
I guess I have alot of questions but the main one's I have is.
Can the engine/tranny come out as one? Do i need to move the exhaust? How many mounts are there?
Any other tips and tricks that might be helpful?
Is there any documentation for this procedure?
Thank you all for your help. This is by far the most difficult engine i will be removing. and might be back for more help.
Brad
Old Sep 17, 2010 | 01:13 PM
Hanno's Avatar
6.9
Brad, search this site for W124 factory service manual. The 4matic is more involved than the standard 2 wheel drive.
Side note.. the e class bible best used for descriptions and general information. It is not by any means a substitute or replacement for a factory or aftermarket service/repair manual.
Old Sep 20, 2010 | 08:08 AM
garrettt3's Avatar
1992 300E 4-Matic
Thanks for your post. I will search for the factory manual.
Really would like to know though if the tranmission and motor can be pulled out as one?
Brad
Old Sep 28, 2010 | 07:13 PM
Makahveli's Avatar
"88 300CE- First Year Production
I need to know this info too!! I doubt it on my m103....I just don't see the room to do it.
Old Apr 28, 2011 | 10:16 AM
ohlord's Avatar
Old post
I know but if anyone is searching,yes you can pull as a unit.
Remove radiator and fan shroud. Remove the side radiator shroud and take off the high pressure line from the condenser so it can be snaked out when you tilt the engine and trans with a tilt bar to angle the two units out as one.
Be sure you put a piece of plywood behind the condenser coils and plenty of moving blankets to guard against the moving engine.
Go slowly till you are sure you unhooked everything,seems you always miss a harness wire or 2.
Old Apr 28, 2011 | 12:20 PM
Makahveli's Avatar
thanx for the info, can this be done with a 1-ton engine hoist or I need bigger?
