Couple of questions about "oil leak" problems (1993 E300)?
Old Oct 21, 2010 | 06:54 PM
chuang's Avatar
2005 E320 Base
Recently I did a oil change and the mechanic told me that he noticed multiple oil leak spots. This is a 1993 E300 that only has 54K miles. Some questions:
  1. Can it be a DIY project if I try to figure out where the oil was coming frm (leaking)? Currently it only leaks a little bit on the garage floor, and when I open the engine hood, I can not see where it's leaking right away...
  2. Based on your experience, what are the most possible cause for the leaking? (which one is most probably? front of engine - timing case cover that leaking or the front main seal? top of the engine - bad valve cover gasket or bad head gasket? or something else?
  3. If the car is only used once a while (e.g. only 1000 miles every year), generally speaking, would the oil leaking problem go really bad in the next couple of years? or it depends?
  4. What are the average parts cost for the following items: (1) valve cover gasket, (2) head gasket, (3) timing case cover, (4) front main seal.
Thanks!
