W124 E-Class Picture Thread
Rating: Thread Rating: 26 votes, 4.73 average.
Old 01-30-2007, 07:57 PM
  #851
nasscmw's Avatar
190E
whoops! thought E420 looks like the 500s. Didn't realise that they look like regulat 124s, my bad!
Old 01-31-2007, 12:11 AM
  #852
rooney2006's Avatar
1991 300E
Originally Posted by CharlestonN
This is my 95 E320 Coupe, lowered 1.5 inches on eibach suspension with 18x8.5" Moven M11 wheels and reflective tint, other than that it is pretty much completely stock, please excuse the bad exposure of the shot, i was just getting use to my new digi at the time . . .
Ill post some better shots later
Things i want to add in the future:
Clear front side/corner markers
Sylvania or Eurolite hid fusion headlight/fog bulbs
Chrome exhaust Tips
you might as well get the whole thing done... tips are gonna cost you probably around $100 plus some type of installation fee.. and a whole custom set up will cost you around $400.
Old 01-31-2007, 04:04 AM
  #853
CharlestonN's Avatar
03' CL55 AMG
The guy that works on my car is hooking me up, it will cost me around $120 for the tips and install and they are high quality tips
I might end up doing the whole assembly later on but for now i just want to clean up the rear end a bit
Old 01-31-2007, 09:24 PM
  #854
rooney2006's Avatar
1991 300E
fair enough. i can respect that.
Old 02-01-2007, 06:42 PM
  #855
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Before: (dont mind me standing there)
And After:
I plan on getting tint and possibly a body kit in the future.
And the rims are most likely temporary, I want something in black, but they were too good of a deal to pass up at $50 for the whole set with tires.
Comments?
Old 02-01-2007, 06:54 PM
  #856
oneill_1's Avatar
MB 300E | BMW M Coupe
Comments?
Wow...the front end looks totally different with those headlights and that grill...and since you made yourself all mysterious looking, post in the ..::Faces Behind the Screens::.. post...
and Welcome!
-OG
Old 02-02-2007, 08:25 AM
  #857
shadowgriffen's Avatar
is a German Tank
Comments?
hey let me ask you, because I've always wondered if I had somehow hooked my headlights up wrong, in the pic with the lights on, you do have the highbeam on correct?
please confirm.
Old 02-02-2007, 03:04 PM
  #858
please confirm.
Yes my highbeams are on.
The thing is, I got the wiring scamatic from the "calling chrisdpham" (sorry if i spelled it wrong) thread, and you posted it. So hell, we could both be wrong.
i know what you mean though. It seems like the brights arent actually much brighter than the normal ones. And you'd think that the outter lights would be the normal ones, considering how funny it looks to only have the inner lights on. Not to mention the inner lights on stock assemblies are fog lights.
Most likely just a cheap product. Seriously...look at the condensation in the one picture. Ive had them less than a month, and the passenger light builds up condensation EVERY time I wash my car, and stays for at least 12 hours.
**wishing I would have saved a little longer for projectors**
Old 02-02-2007, 07:11 PM
  #859
battlecat714's Avatar
a TVR Cerbera Speed Twelve
I don't know if you're willing to try this, with the headlamps being new and all. This was something suggested for that condensation problem:
Originally Posted by Eric@StarSuzuki
However, for a "temporary" fix, I've drilled "drain" holes in the bottom of the lamp assemblies before. It isn't the most elegant solution, but it will let the moisture out. Heat from the lamp itself will dry the thing out if there's a way for fresh, dry air to get in. Putting the holes in the bottom will let any excess water from rain or whatever drain out first, too.
Small, like about 1/8" (3mm) diameter. Drill 2 or 3 along the bottom most surface of the reflector, near the front where the lens attaches. Don't drill directly into the joint between the lens and reflector, though.
I've done this to several polycarbonate US spec headlights on different vehicles. Most had heat stress cracking across the top part of the lens and would get water in during rain storms. One would actually collect enough water to flood to the point where it would shatter the bulb when you hit a bump or went around a corner.
The goal when making the "fix" is to be unobtrusive and inconspicuous with the drilling. It won't be "invisible". But it's also not something you really notice if you aren't looking for it.
Old 02-03-2007, 02:59 PM
  #860
Its not so much condensation that i need to drill holes haha.
Just a light layer on the inside of one assembly. It goes away after a few hours when the lamp heats it. Im assuming it evaporates out the same way it come in.
Not a big deal, just kinda frustrating.
Old 02-05-2007, 08:20 AM
  #861
is a German Tank
Really? I GET ZERO condensation on my healights. the corners on the other hand came with the weather trim unglued! I had to re-glue the trim back on in order to feel better about myself
I have actually confirmed with the seller and they are on correctly.
meh.
Old 02-05-2007, 06:38 PM
  #862
meh.
Now that you mention it, the weather stripping on mine was loose too.
I kinda tucked it in until I got the right glue. But never did get the right glue, an it hasnt flopped out for a while so it hasnt bothered me.
Im satisfied overall, but I still do kinda wish I wouldve held out for the projectors. If I could return them and pay the different i would.
Did that **** ever leave you freakin feedback? I know he didnt me.
Old 02-05-2007, 09:33 PM
  #863
kiasu's Avatar
260E
my 1st impression haha..
Old 02-06-2007, 12:46 AM
  #864
mgw_300e's Avatar
Dora the Explorer
That's exactly what I was thinking!
Old 02-06-2007, 01:17 AM
  #865
ShanMan's Avatar
'95 E420 SE
d i t t o !!!
Old 02-06-2007, 08:06 AM
  #866
is a German Tank
hmmm....I don't know I dont think mine looks like a Bently at all
Old 02-06-2007, 10:33 AM
  #867
kiasu's Avatar
260E
its more the combo of the replacement wire mesh grille and being black i guess and with those type of headlights, im not pointing the finger to laugh here i just had that image in my mind
Old 02-06-2007, 08:55 PM
  #868
hahaha I get that sometimes.
My brother said it as soon as I put the headlights on, and my friends always ask if Im "gonna come through in the Bentley."
Old 02-06-2007, 09:22 PM
  #869
CDP
CDP's Avatar
W124's
My car along with gay a$$ omar's car at a meet a couple weeks ago on Jan 20th...
Old 02-06-2007, 10:45 PM
  #870
why wasnt i invited?
I think I saw you on the 91 today around the 57. I saw the black grill for sure but I couldnt see what the rims looked like while they were moving.
Were you anywhere near there?
Old 02-07-2007, 12:02 AM
  #871
CDP
CDP's Avatar
W124's
haha.
The meet itself was posted through every section on the forums to remind local members. You missed out!
Anyways, I was on the 91 & 5 earlier today since I was leaving HoI's after work but I was no where near the 57 Freeway.
Where are you located? We should have a photoshoot one day.
Old 02-07-2007, 12:07 AM
  #872
ZedStyle's Avatar
Youngtimer
i always find it strange how west coast people say 'the' before the number of the highway...
Old 02-07-2007, 03:00 AM
  #873
CDP
CDP's Avatar
W124's
lol. Isn't that the proper way?
Old 02-07-2007, 10:41 AM
  #874
mgw_300e's Avatar
Dora the Explorer
That's how it's said everywhere but the south I think.
Anyway, here's a pic of my grill - I just blacked it out and replaced the front badge. My old badge had lost most of it's blue border. I'm also throwing in some pics of the whole car since I haven't posted any in a while.
Before:
After:
Old 02-07-2007, 11:09 AM
  #875
marco402's Avatar
2001 W208A
cool, i think i like that, maybe I can even afford to do that......
You have already rated this thread Rating: Thread Rating: 26 votes, 4.73 average.
Quick Reply: W124 E-Class Picture Thread
