WEIRD electrical issue...possibly relays?
I was driving my car yesterday and noticed that my power seats and mirrors were not working. After looking around to see what else wasn't working, I discovered the windows and sunroof weren't working either. I figured it was a fuse, but they are all fine.
I then figured out that the seats work fine if the door is open and the push-switch in door jam is open, but when the switch is pushed in (door closed), the seats don't work. Then my mirrors came back and work fine now. I found that when I push the window switches, I hear a clicking noise like normal and traced it to the box on the driver's side, under the rear seat. It clicks every time I push any of the window switches but hear nothing when trying to use the sunroof. I know the switches are getting power.
Does this sound like a relay issue and if so, where is the relay? Is it part of the electrical box/connections under the rear seat, behind the driver? Someone posted that relays are under the hood, under the electrical box, but those were on coupes. I'm at a loss and it's really annoying. Oddly enough this happened the day after it had been raining a lot.
When I searched, I came up with posts that only had the sunroof/window issues but never anything with the mirrors and the weird power seat issue when the door is closed.....
Any help would be greatly appreciated. Thanks
-BJ
When in doubt, change all your fuses. Cheap and easy preventative maintenance. Hope this helps the others that posted similar issues and never wrote back with the problem solved. If you have the same weird issues I did, check your #2 fuse.
BJ
I also think that could be your Convenience relay. Check under the rear-right seat. There should be a relay there (and possibly more fuses).
I had this exact issue and it turned out it was just the regular fuses having micro-fractures.
I usually have difficulty finding the cylinder fuses in regular American Autoparts stores. Its pretty simple to tell the difference. The copper fuses have a gold/copper strip, while the aluminum ones are a dusty white/silver strip.
