rear end link
I was looking into making my own but adjustable. They aren't that hard you'd just have to have the parts and know how. If you want we could probably get a group set since buying more makes parts cheaper. You shouldn't spend more than $150 on an adjustable pair.
Let me know if you'd want a set and I'll go ahead and order the parts :thumbsup:
(I have adjustable camber arms fitted already, these won't 'stiffen' anything)
For the swaybar to be adjustable it would need multiple link points (ie, to the front and rear of the original link point).
This would create a pivot/lever effect and alter swaybar stiffness
Camber does nothing for stiffness of the ride. End links are connected to the sway bar and create tension or compression which create sway or stiffness for the ride.
i think raising the ends would increase under steer, and lowering the ends would increase over steer, but not sure on the amounts, and whether it would be the same as fitting a thicker/thinner bar, i think probably not, but it may make enough difference for very fine tuning, but not noticeable on a road ride with std power, unless you drove it like someone stole it.
MB does make an OE metal link, while the one any parts guy will pull is made of plastic. Not sure what the PN is but it is out there.
I suggest that when you install the bolt back in, switch the position of the nut/bolt so that at the next change (which after replacement should not be in a while) the shock doesn't interfere.
It's pretty straightforward.
The correct way of adjusting the endlinks is having the car on a flat surface while supporting it's full weight
