Austin2Chicago: 93 300CE Cabriolet
All the paperwork, inspections, trip route, travel bag and other deets have been covered, and now I sit here wondering if I can get to sleep. I bought a cheap one way ticket which means I need to spend about three hours in Denver, which will allow me to collect my thoughts on the entire buying process, which I must admit was a bit choppy but thanks to you kind folk I feel the decision is sound.
This is my first Mercedes Benz. 1993 300 CE Cabriolet. And its perfectly suited to me. All black. Needs some attention, but mechanically sound. 73K miles. Everything works except for a wonky volume control and woofer pop in the stereo (aftermarket Sony) and non working but clicking every mile trip odometer. Sure, its not perfect, but its very clean, original and now mine.
I plan on documenting the trip here and per request I will eventually submit it to MBCOA for the magazine. We'll see if anyone finds the story compelling enough for print. If they do, I may be able to expense some of the fuel. I'll bet they like the pictures better than the words, but I'm cool with that.
Thanks again folks. Can't wait to smell the road.
Bob
Bob
Lots of choices for mats,
ebay always has some choices,
performance in california has expensive ones.
I like the rubber mats for a black regular driver.
Have carpet mats in my Cab, but only run it about 2500 miles per year.
So, I seem to have a hydraulic leak. The top is operational, but I can smell the fluid and it is weeping into the roof when the top is stowed. I will be on the road for three day in great top down weather. Is the fluid going to to permanent damage to the inside roof liner? What about the vinyl on the surface of the top trunk? I plan on putting it up and down until I get home? Bad idea?
2004 SLK 230, 1992 300E & 400E
I think I'd just leave the top up instead of taking a chance that the inner liner, etc., could become damaged (it'll probably be an easy fix for the leak, but it wouldn't be an easy, or inexpensive, fix for the headliner nor the shelf. Trust me on this..........I've got one.
Hmmmmmmmm - part of me says don't be concerned.
3 days is not going to screw the pooch permanently BUT staining might be an issue. Then again if the leak has been around for awhile can you see any evidence of it having happened for sometime ?
Is it a leak due to infrequent operation - i.e seals dry ?
Having read vexed's post about his cab hydraulic overhauls would seem it's characteristic of the model (bit like the wobbly fuel gauge is standard
). If you can I would maybe leave it down for awhile then back up when you hit the first bit of cool weather - and leave it there until you get home.
So tell me is it as good as it's picture's ? Very jealous mate !!!
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
It's as good or bettr than the pics. Everything works perfectly, sans the leak and head unit radio and I'll just keep the top up, roof and liner are brand new! It's pretty hot here even wit the windows down and I want to vent the fumes as much as possible. Cheers
Cars a peach. Kept the top up and most of the smell is now in the trunk, the cabin is clear. Some staining on the liner. Any ideas how to clean it? I may have an exaust leak, a little hissing under the drivers door, I'll check when home and check/fill all the chassis grease fittings for the winter. 498 miles ticked by effortlessly. Speeding the night in Hot Springs, AR, then north to Hannibal, MO tomorrow morning.
I was going to say Bob - your not sticking white substances up your nose are you ?
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Been hit by bug-shrapnel with the top down at all ???
I am so thinking I need to get me one of those things - maybe it would be worth it if I found one at your price and had it shipped over.
Just have to figure out how to left hand drive on the wrong side of the road !
I got home today, much too soon. Really wonderful car and I found some really terrific roads for two and three wheels. And over the weekend the leaves were turning, not much traffic, I really got to know the car and never really thrashed on her at all, but had some sporty fun in the Ozark mountains. I did my best to be kind to the brakes but when it needed to happen they worked great. I hope they can always be that good.
I'll post with more detail but here are some of my observations.
The 4 speed is unlike any I have driven. You can gingerly pull from lights or increase your speed for passes and you feel the momentum building, but push down against that massively sprung accelerator and blammo. The kick down took me by surprise the first time I found it. That felt fast.
The headlights are really iffy in rural areas and especially in the forested twisty roads. I like the fogs, they illuminated painted roads well, but those without paint had me seriously struggling through. Pace just over the limit, nothing gumball. I wonder if I just replace the stock bulbs for a result. The brights worked well for my old eyes. But turning them on and off was kinda distracting.
Holy independent suspension batman. First few miles I thought for sure that springs would need swapping in the Spring. But not now. What a plush high speed set up that is. and with the steering, I think I like it as is. Anything stiffer will hurt around Chicago. And those cowl shake dampers would be toasted, as in catch fire. I absolutely love how this car reacts to driver input. Just enough help but not too much to make you flail. Again, I hope it will drive this way for ever.
Tire choice from the dealer is very capable. I did hear some pitch increase in the Ozarks but that could be from a lot of things. Where I did hear them squeal was in a unpopulated round about made of new cement. I did an impromptu skid pad excercise and was surely heeled over quite a bit but they held the carve. They are Continental Conti Pro Contact 195/65 R 15 on the 8 hole wheels. I was on some cold wet stuff and they worked well there too.
The top. Dammit. This was a tough part of the sale, but I am not looking back in any way. So we had it up and down a few times, put it away in the boot, and soaked 30 percent of the brand new top and liner in hydraulic fluid. Bother! But, its going to be okay once the leak is found. I'll search the list for some additional knowledge here. The top construction is amazing. And the cabin is seriously quiet when all closed up.
Climate control does as it should. Simply. I like that. Along with the cruise control, wipers, window controls (nice auto down detent, found that out in Arkansas).
Drivers door cladding has two released clips. Guess pushing on them wont help. This looks to be a source of water getting in behind the cladding over the winter and when washing the car. will it drain out the bottom somehow or just sit inside? I don't like the latter and may put some clear tape (1/4") to keep the water out until I get into the fix it mode.
Seats. Come on. These are the best seats ever. I want to go to the junkyard and make them into office chairs. Off the hook for sure. I did have a nervous moment when the drivers side recline operation inverted. I kept tapping, tapping, tapping until it was nearly pushing me into the steering wheel. It finally got to a point of embarassment when it released and recline did recline. Maybe the car wanted to go back to Texas? Nah.
No leaks or loss of oil except at the filler cap. Weeping a bit. Any suggestions?
Steering lock. The turn radius on this car is excellent. Like it has a bow thruster or something. I couldn't get over it.
Where can I get replacement headlamp wiper blades? These are shot.
More later. You were all right. Best car ever. Very fortunate to know you and even more fortunate to have score d this as my first Mercedes Benz.
Prost!
Bob
Prost!
Bob
YeeeeeeHawwwwww ! We dun converted him !
Actually Bob I know the feeling, my 300CE is my first Mercedes and despite it's age gives me such a wonderful feeling when I drive it. It's solid and classy and yet it can rage like a bull when you ask it too. No it's not a tarmac burning V8 covered in plastic and gutsy roaring - it's sedate and classic.
I agree about the seating, at first I thought no too springy but you know what ?
After a decent drive I step straight out without feeling tired or sore.
The brakes are nice and beefy, you don't feel like they are going to let you down in an emergency and having ABS on a car of that vintage - WOW !
I'm so glad you made it safe and sound without major failure or mishap - look forward to hearing of your restoration projects as they go along.
Headlights are an often discussed topic on here. The US models seemed to have been punished by regulations when they were imported and crappy lights is the result. I had an issue with headlights being poor out in the boonies, but mine was because they had been dressed it up with "blue" inserts which gave about as much light as Mars does on a cloudless night ! I actually put a reasonably inexpensive option in. In Oz they are called Narva Arctic Plus 50's .
http://narva.com.au/products/browse/...globes#anchor4
In the US I believe they are called Narva Rangepower +50's.
http://store.candlepower.com/naraulhiou60.html
You will be amazed at the difference - still not perfect but heaps better. Be aware of the dangers of putting stronger bulbs in than the specs originally fitted (55watt I believe).
What does the family think of your new ride ?
The line starts here * for the keys ?
Ray
Ray
My wife loves it and hasn't even been behind the wheel yet. My sons want to see it transform, but not yet! Max (4yo) says it looks fast. Batman fast.
Best 1380 miles I've ever had.
Maybe you should change your Username & Profile
batman
1993 Batmobile E -Class
![Name: batmobile_small.jpg
Size: 7.9 KB](https://mbworld.org/forums/attachments/e-class-w124/220888d1319507678-austin2chicago-93-300ce-cabriolet-batmobile_small.jpg)
Drives: 00 Audi A6 4.2, 93 Batmobile Cabriolet
You better watch out BATGIRL may decide she thinks the 300CE is way too good for you and you'll never get to drive it !
Either that or she will put out her hand for one also !
Sure! I'd be happy to oblige with a 500E. Nah. I'd stick to the coupes I think. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
@ stormtigers I just ordered the bulbs. I just cant get over the orange glo of the low beams. It's like the car is tired and wants to pull over and nap. Thanks for that link.
@RHW
I went over to my neighborhood hand wash car wash today. I live just off of Route 66 and were all pretty proud of that here. Anyway, he had a set of carpeted floor mats that we test fitted in the car hanging on the wall. They fit. Cost for two fronts and two backs: 20 bucks. Piece of mind for the winter at least.
Final trip update. In HD video!
There is really no reason to watch all of this, but the entire adventure is captured in 33 short episodes of uncut, unfocussed and sometimes surely inaccurately narrated digital video.
http://tinyurl.com/3lo5n4v
Just toggle the sort to “added first” and they will play in order.
Enjoy.
Enjoy.
OMG I almost crapped myseld laughing at the first one ! ![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
"THE SMELL OF LUXURY IS HYDRAULIC FLUID ? "
BOB your a regular Oscar Wilde !!!!
Wait to Shoomakan hears that one !
He cracked up over my "chromies is for Homies" in the wheel replacement post.
OH and don't give up your day job for singing !
Tales me back to first moments in my Cab, disbelief at how smooth the car handles 70mph, looking around at cars "worth" twice as much, despite that I'd prefer to be in my Cab.
So, what'ya figure, maybe 40 black on black 1993s in the country 18 years ago? How many are left? How many have sub 80K miles? I heart your car.
