Coolant problem
Old Jun 13, 2003 | 09:25 PM
MBDriver's Avatar
2001 E 320
Coolant problem
My brother has a 93 300e. It keeps loosing coolant from the passenger side in front of the door, it leaks. Mechanic said no problem with hoses and i changed the thermostat and the housing. What is the problem? Could it be from the radiator cap? Any help is greatly appreciated.
Old Jun 14, 2003 | 07:39 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
Just a thought - but sometimes the overflow bottles develop a leak. For these elusive leaks it sometimes helps to pressurize the cooling system with shop air to uncover the leak. Use no more than 15-20 psi.
Old Jun 14, 2003 | 07:45 PM
tonystewart's Avatar
84 300D 93 300D
Check the coolant level sensor in the coolant recovery tank. I have seen this leak misdiagnosed as a coolant tank leak.
Old Jun 15, 2003 | 12:46 AM
MBDriver's Avatar
2001 E 320
Thanks for the advise, I'll try it out. Any other advise still welcome in meantime .
