88 300E Cold Air Intake Project
Old Apr 25, 2012 | 06:02 PM
Jesse88300e's Avatar
1988 Mercedes-Benz 300E
Smile 88 300E Cold Air Intake Project
so i have been researching air intake options for my 88 300E because A: I dont like the look of the stock air cleaner B:i want to attempt to improve my performance.
ive seen a few people pull this off but they placed the filter in an ugly position where there is little to no air flow my idea is to run my pipe over the valve cover and place the filter behind a custom heat shield near the passenger side head light. i was thinking of fabricating an air duct under the bumper to divert air to my filter.
i think this may work and im gonna give it my best shot. has anybody else attempted this?
Old Apr 25, 2012 | 06:52 PM
ptoro01's Avatar
86 W124
If you search around, you'll find that you should keep it as is, but if you'd like to make it better, a snorkel is the only thing that actually works.
Old Apr 25, 2012 | 06:59 PM
it seems that most of the info i found says it doesnt really make a performance difference, just visual. some people said that the stock cleaner muffles to sound of the engine and it sounds better without. I might try it just for the hell of it.
thanx for the info though, i'll look into the snorkle idea for sure.
Old Apr 25, 2012 | 07:58 PM
neanderthal's Avatar
You're NOT going to improve the performance at all.
You might improve the aesthetics (according to you) but at the loss of what?!?!?!
Old Apr 25, 2012 | 08:14 PM
Wow calm down...didn't I just say that this will more than likely NOT IMPROVE MY PERFORMANCE.
This is something I am going to ATTEMPT, its just an EXPERIMENT on MY vehicle.
There are a lot of very nice, very helpful people on this site and I appreciate everyone who takes the time to answer my stupid questions. But don't act like I'm an idiot just because I wanna try something different.
Old Apr 25, 2012 | 09:26 PM
190E 16V's Avatar
1987 560SL
Cold Air Intakes have been discussed, at length, before.
Try this link for a thread with the Poster Boy of Dysfunctional Posters, Zach1328.
https://mbworld.org/forums/e-class-w...-upgrades.html
Old Apr 25, 2012 | 10:08 PM
Saijin_Naib's Avatar
1990 300ce 24v I6
Jesse, I'm toying around with the same idea. However, the important thing to note is that the w124 already comes stock with a cold-air-intake, so as noted above, improved performance is likely impossible.
All you can do is unrestrict it a bit by changing the airbox and make it a colder air intake (as I did) by insulating it with some high R-Factor insulation wrap. Another alternative is to use partitions to partition it off from the rest of the bay.
I'm going to work this summer on making a "track-kit" intake that will bypass the stock airbox and bolt straight to the throttle body. Reason? I want to hear the intake noise.
Go ahead & experiment
Old Apr 25, 2012 | 11:32 PM
Thank you. That's all I needed to hear. I like your track kit idea I'd be curious to learn more on how one could accomplish this. Looking forward to pics when you get started.
Old Apr 26, 2012 | 03:44 AM
Suit yourself.
Those of us who have been on this board long enough have seen the millions of threads from new owners about increasing the power and all that. None of it works. You think AMG and everybody else bored out the engines because they wanted to go one step bigger or because there weren't significant gains by just changing the cam, the intake, and headers, using a high perfomance exhaust, like you'd do on a BMW or a Japanese car?
The M103 does NOT sound sexy. You're going to get more noise. It's not going to be sexy noise. If that is what you want, go for it.
Old Apr 26, 2012 | 11:48 AM
1990 300ce 24v I6
M104 sounds pretty hot though
Is the m103 really that different in sound?
Old Apr 26, 2012 | 02:52 PM
ptoro01's Avatar
86 W124
I have a K&N in there, not for performance but cause its a cost-wise clean able filter, and yes it does sound a bit different. The engine vacuum isn't muffled as much. It's subtle enough, mostly on releasing the throttle fast, as it recoils..
If you want a colder engine bay, get a new fan clutch and hood vents....
As I keep repeating, fix the wear items! Your engine air intake will work its best if there are no vacuum leaks; all the rubber vacuum hoses, properly sealing valves, a good camshaft...
The M103 is different in not having variable cam timing, it screams as opposed to grumbles...
Old Apr 26, 2012 | 05:54 PM
Way way way back when I used to be a mechanic, the shop manager and body shop manager raced a 300GE in rallies. This was in Africa.
That thing sounded marginally better than a tractor. Bone stock engine, modified intake and exhaust. The mods were more for water fording than power.
Old Apr 27, 2012 | 04:00 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
M103'S don't sound that bad..............
Old Apr 27, 2012 | 05:42 PM
chlippo's Avatar
300E W124, 300E W124 3.4 AMG, Audi S3 2002
http://www.youtube.com/watch?v=oRCVtjcyV8w
Brett i beleive the sound clip is from an HFM M104...totally diferrent story that our M104 CIS.
Old Apr 30, 2012 | 09:12 PM
2PHAST's Avatar
500E Signal Rot
**** me! That thread was painfull to read.
Someone needs to give Zach the
Old May 1, 2012 | 12:41 PM
190E 16V's Avatar
1987 560SL
We should make a "Sticky" of it, "Easy & Cheap W124 HP increases"
It just kills me what he has said...
ZACH wrote:
"Don't forget that I-6's are some of the most easily tuned engines ever made. Unlike most cars our engine bases' have plenty of room to stuff parts in there.
I've also been looking at getting the 5.0L V8 from the 500E, but idk how much that would cost."
Old May 1, 2012 | 03:38 PM
RHW's Avatar
RHW
94 Wagon and 94 Cabriolet
Was a very funny run with Zach, some Beemer boards are now enduring same.
