Mercedes 5.0 in a W124
Old Aug 21, 2012 | 10:34 PM
w124v8's Avatar
1992 400E
Anyone know if it is possible to swap a SL500 egine( or any other series 5.0 or larger) into a 1992 400E? Wondering if the M119 4.2 tranny olts up and what wiring/electrical mods must be done. Any info helps, thanks.
Old Aug 21, 2012 | 11:26 PM
desired_speeds's Avatar
2007 SL55 AMG
its very possible because the 500E had the R129 sl500 engine
Old Aug 21, 2012 | 11:44 PM
neanderthal's Avatar
External dimensions should be the same.
Old Aug 22, 2012 | 02:13 AM
w124v8's Avatar
1992 400E
Thanks for the info! Do you happen to know if the 722.3 from the 4.2 will work with the 5.0? Would it be a simple ecu change in the wiring department? Thanks again!
Old Aug 22, 2012 | 02:54 PM
ZorroAMG's Avatar
Enzo, my Benzo
I believe the v8-v8 swap is rather easy as it's the same block, just different bore if I'm not mistaken. Best of luck!!
Old Aug 26, 2012 | 06:15 PM
w124v8's Avatar
1992 400E
I was reading more on this and found on one site that the block (sl500) has different mounting locations and the electronic/ecu differences make this swap a real pain in the **** From what I have read it is the same exact block. I can't really see them making a new cast for an engine rather than desiging around same one they have/had. Can anybody clarify this? I think if I had agood donor car with all electronics and mounts it should not be that bad. If the bore is the only difference between the 4.2 and the 5,0 has anyone ever tried to bore out the closed deck 4.2 and run the 5.0 pistons? Obviously,you would need to have the cylinders coated again, but many shops do this now for decent price. Just curious. Sorry for the long post
Old Aug 27, 2012 | 06:16 AM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Less expensive if you purchase a 500E/E500 which will hold and probably increase in value...
Old Aug 27, 2012 | 10:42 AM
w124v8's Avatar
1992 400E
Originally Posted by w124v8
I was reading more on this and found on one site that the block (500sl) has different mounting locations and the electronic/ecu differences make this swap a real pain in the **** From what I have read it is the same exact block. I can't really see them making a new cast for an engine rather than desiging around same one they have/had. Can anybody clarify this? I think if I had agood donor car with all electronics and mounts it should not be that bad. If the bore is the only difference between the 4.2 and the 5,0 has anyone ever tried to bore out the closed deck 4.2 and run the 5.0 pistons? Obviously,you would need to have the cylinders coated again, but many shops do this now for decent price. Just curious. Sorry for the long post
Does anyone have any technical info from the above questions besides, "buy a E500E".
Old Aug 28, 2012 | 12:00 AM
Quicksilver500's Avatar
1992 Mercedes-Benz 500E
Yeah if you won the lottery. You could sell you 400E and for what MB would charge you for 4 pistons you could buy a 500E. Not to mention the machine work, cylinder etching (Alusil? SPECIALTY and illegal in some US states due to the chemicals), cams, crank, rods, 4 more pistons, injectors, ETA depending on ASR, LH chip, brakes, suspension, recaro seats, sport steering wheel, fancy burl wood, AWESOME fenders, huge sway bars, etc etc etc. 500E v8 is slightly different from the SL M119. Mercedes didn't spend 18 days building each car, utilizing the old porsche 959 production facility because it was basically a 400E with a few more cubes and a bumped sticker of $20,000 over the 400E. There are huge differences between the two cars. RBYCC is trying to save you a huge headache.
There are only a few years of LH SL/S500 V8s between CIS and ME1.0. The 500E only had 119.974 engines I think, some closed some open, all short deck. Long block from MB $45,000.
Old Aug 28, 2012 | 12:46 AM
w124v8's Avatar
1992 400E
I like the "built, not bought" option if I didn't want to spend money on it I would have bought a Kia project car (could get more useful info probaly)... go ahead and hate! I'm not trying to build a 500E contrary to popular belief. I'm done lock it up or delete, as this is going nowhere as far as useful info... unless you need a reason to buy an 500E
Old Aug 28, 2012 | 07:45 AM
I told you EXACTLY the m119 v8 to look for, whats more useful than that? If you want to build a 4.2 into a 5L you will need most of those parts I listed. To get info you have to ask the right questions, and you need to do enough reading to understand the answer to those questions. Like now would be a great time to look up what a M119.974 engine is.
Old Aug 28, 2012 | 08:03 AM
RBYCC's Avatar
You're new asking for advice which means you don't have the answers..
"Hate"...what, why...you've got nothing to "hate" over...also indicates your level of maturity..
You get responses from those who know the costs and the problems but don't like the answers you get...
Don't ask if you already have an answer firm in your head...
Just another "Zach"
Old Aug 28, 2012 | 02:48 PM
w124v8's Avatar
1992 400E
Just another "Zach"
Uh hunh
