Aftermarket amp install turn on wire!!!
Old Apr 13, 2013 | 08:24 PM
redciv1's Avatar
2007 CLK350 Convertible
Hey. So I purchased an Alpine UTE-42 and installed fine, great unit. Question I have is the amp turn on wire. I have a harness that plugs into the MB unit and then into the Alpine harness. I was told that the Amp turn on wire(pink) was to be used for the Antenna as well as the remote turn on wire for a aftermarket sub. Just need someone to confirm that has an aftermarket amp.
Old Apr 15, 2013 | 04:28 PM
ZedStyle's Avatar
Youngtimer
harness?? man... i had to do mine the old fashioned way!
I'll check for you at home which wire i used for the amps. the antenna has its own wire but you could splice it into the amp turn on too. My antenna didn't work so i don't have it hooked up any more, but i will check the amp wire for you
Old Apr 15, 2013 | 05:03 PM
redciv1's Avatar
LOL ZED. I think I did one car years ago w/o a harness. Can't even think about doing it w/o a harness. BTW, where did you ground your amp? I have it ground next to the battery in the factory spot.
