E420 SLS?
Putting a m119 in a I6 w124 requires a new k-member (chassis part under the engine) and different firewall section. Its been done before but with 5 to 6L m119 motors. So the SLS will be the easy part.
-Mike
Also remember the trans bell housings are different. V8 cars had a 4 hole yoke and I6 had 3, v8's also had electronic speedo, so you may need a cluster swap, neutral safety switches are different (v8 is a 6 wire, I6 is 4 wire) which won't matter if you do aftermarket fuel management probably.
Also look into 500E springs. I put an old set of mine on a buddy's wagon and it was very nice. The V8 is only like 80lbs heavier, but its still heavier.
This picture shows the CAN control box in a V8 car.
http://www.mbca.org/sites/default/fi...D%20Module.jpg
Not trying to be a PITA but just trying to give you some knowledge so you can try to get a broader picture of the differences.
From a parts car ((E420) ill be taking the entire harness and swapping out the original wagon harness and peripherals that are different. I have an idea for a battery that I'm researching now.
I value your input. Thank you.
