Air Conditioner Leak
Old Sep 3, 2003 | 07:07 PM
Brian McL's Avatar
Hi...I would greatly appreciate anyones input on the "known" problem areas in the 124's A/C system for 1994 E320. I have a leak inside the car and I'm hoping it isn't the evaporator. I re-charged the system with a scented hydro-carbon (134 substitute )and the inside of the car has a very strong odour after sitting over nite. The charge is gone in 3 days....so it's a big leak. I'm pretty sure the leak is inside?
Can anyone start me off in the right direction. :(
Old Sep 3, 2003 | 10:13 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
You need to narrow down the leak source. I like to look for leaks by flowing a soapy water solution over suspected areas. Any leaks show up as bubbles.
The best way to confirm evaporator leaks in a working a/c system is to inject a UV dye into the system, then check for leaks with a UV light. Evaporator leaks will show up as UV dye in the water condensate.
Old Sep 3, 2003 | 10:19 PM
Brian McL's Avatar
Thanks....good idea. But what next???? First the head gasket, then the wiring harness and now this....never had this much trouble with the 1990 300E.
Old Sep 4, 2003 | 09:03 AM
Kestas's Avatar
Let's see...... creaky door check straps..... headrest mechanism..... radiator neck...... flex discs.....
Old Sep 5, 2003 | 09:12 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Unhappy
unfortunately there is not much else inside the car of A/C components than the evaporator. It's not a cheap adventure since the whole dash has to come out first.
Old Sep 7, 2003 | 11:14 AM
sshores's Avatar
1995 E320
OUCH
I had multiple problems with small leaks, (recharge 1LB ever 2 months). The ONLY way to find a small leak is to use a freon sniffer. I think the evaporator coil is a prime candidate if you can't see the UV dye. The estiamte for my repair from the dealer was 2 weeks (80 hours @$80/hr) labor and the part itself for a grand total of $2750.00.
Take it to a shop or a dealer with a sniffer. Hope you get better news than I did.
Old Sep 7, 2003 | 11:40 AM
sshores's Avatar
1995 E320
OUCH
FYI, I have a friend who services MB's. He told me that he has used a 134A system sealer on small leaks.
It takes about 3 hours to set up and you need a vaccuum pump to evacuate the system. He told me that he did this on his Benz and it held a couple of years.
The thing that I am not sure of is how large the leak can be and have this leak sealer work. The kit costs around $45.00. He uses Adsit or IMPCO for most of his parts.
Hope this helps.
Old Sep 7, 2003 | 12:56 PM
Brian McL's Avatar
HI and thanks for the responses....well, it IS the evaporator. I took the whole dash appart to get it out. I mean EVERYTHING. Thought I would just remove "this panel here and see if I can get the sniffer in there, hummm, nope......well, maybe I'll just remove the airbags, see what I can see" 4 hours later I had the whole thing out on the floor. The evaporator sits in a mixture of sludge and yuk....the drains are clear but there is always a caustic mix of "stuff" there that eventually eats it's way through, and presto!!! a leak. Now I need to find a good after market replacement...any ideas?
It maybe a good idea to revese flush yours through the drain holes......I sure will.
Brian
Old Sep 7, 2003 | 01:33 PM
sshores's Avatar
1995 E320
MB Links
Lots of links to MB repairs here, try this URL.
http://my.net-link.net/~rgginger/mercedes.htm
This link shows evaporator coils at half the price I have been quoted. I've gotten brakes and rotors there, no problems with them.
http://catalog.thepartsbin.com/?year...mageField.y=15
Sorry, but you did get to the problem really quickly.
Old Sep 8, 2003 | 11:08 AM
Originally posted by Brian McL
[It maybe a good idea to revese flush yours through the drain holes......I sure will.
Brian [/B]
how can this be done w/o flooding the car. Just using a garden hose???
Old Sep 8, 2003 | 11:09 AM
Brian [/B]
Brian [/B]
Old Sep 8, 2003 | 11:24 AM
Kestas's Avatar
Did you find the leak point? I'm curious what the common failure mechanism is for these evaporators. Some say it's the thermal cycling of dissimilar metals. I wonder if it's the acidic action of decomposing leaves and other organic matter eating through the metal.
Old Sep 8, 2003 | 11:43 AM
Brian McL's Avatar
The leak was in fact in the middle of the evaporator and not at the bottom, as we expected once it was removed and we saw the condition of the tray it sat in. The fins at the bottom had started to dissolve....but the the leak was no where near the bottom. The metal in the area of the leak is all aluminium, fins and tubes...so go figure. There doesn't seem to be any logical reason for it. Maybe MB ordered this part to "biodegrade" like the wiring harness on the 104 engine. Problem is.... it starts braking down long before your ready to recycle the car.
Old Sep 8, 2003 | 11:49 AM
Brian McL's Avatar
The inside of the plastic case that the evaporator sites in has a plastic "dam" around the bottom. It's about 1 1/2" high, so it will take a far bit of water before it over flows. Don't forget, this area is meant to hold and shed water. Now, when you "flush" it put the water on very low, not full pressure from your tap 'cause then it will flood. Just a nice light flow. Run it for a couple of seconds and let it drain out. I would think repeating it 2 /3 times wouls be enough to flush out the nasty stuff. It should be something to do twice a year.
Old Sep 8, 2003 | 01:21 PM
Kestas's Avatar
Designed to hold water!!!!!.... Who's the idiot that came up with that brainchild!!!!!!!! Now I'm worried about my system. I thought my car was immune because people reported that it's not a problem with the 95 W124's. Can somebody confirm or deny this?
Brian, when flushing the evaporator box, where would you introduce the water? I think it may be a good idea to do this task every so often as preventive maintenance..... especially if people park under trees. (Oak leaves are the most acidic.)
Old Sep 8, 2003 | 06:32 PM
Brian McL's Avatar
Now that I've got the the whole system out, the only place that I can see to get water into flush is up through the drain. Unless you want to put an "inspection" port (drill a hole) on the top side, inside from the passenger foot wheel. Requires removing the carpet. Actually, that may be what I do. The chiller is to the rear and is not visible. The front one that you maybe can see through a vent is the heater core. The chiller is right up in behind. Almost under the windshield. Good luck.
