Are there any tricks to this? 1>2>3>4?
Highways I have no problems with.
Mine has 2/3/D/N/R/P. When I lock it into 2 though it will usually go into first - if at a dead stop.
** Update ** I was driving to rugby practice tonight and I had an immense amount of stutter from the engine. Anything 3/4 throttle and it bogged BAD. Anymore and it would kick down to the next gear, and less and no big deal.
When I was leaving practice the idiot light came on, and the symptoms seemed to intensify. It didn't feel like fuel cut - it felt like something was really holding back the engine...
I'm kinda upset, it was running so well too.
However, it's when I shift into 2nd - no matter where in the rev range it will quickly shift to 3rd. -That's- what is bugging me.
I just finished flushing the transmission and used Dexron 3 and a fresh filter when I changed it out. I think I may have adjusted the throttle/cable - I followed the instructions to the letter, but definitely worth going back and double checking.
Let us know how things turned out after that bit of maintenance.
It seems like it does alright - I just hate that it's so gutless, the economy gauge can be all the way in the red and it feels like it's barely moving. Pretty disappointing.
The hesitation is still there though @ ~ 75% throttle it just bogs terribly.
I have not yet gotten to adjust the bowden cable - we've been under about 6in of snow recently so I'm just focused on day-to-day stuff.
The next time I take it into the bay it's getting O2 sensor, fuel filter, timing cover gasket, and front flex plate - and it will be then that I can break down and really get at it.
Let me ask you a question, I followed the instructions in this thread: http://www.benzworld.org/forums/w124...on-cables.html
And the result is what I'm currently experiencing. What did I do wrong?
I put it up on the lift last night and did the O2 sensor and fuel filter. I had my mechanic buddy look at the trans/throttle cables and he played with it a bit, fixed almost all of the hesitation (the last little bit could easily be the "arrows aligned" and I can do that when I get another crack at it.
He adjusted my throttle cable to 100% taught, but now my fuel economy took a crap. Normal? It seems odd that I would get WORSE fuel economy with a fresh fuel filter and O2 sensor..
Is that about what you're getting?
And I changed it to this:
So, no arrows, but I'm fairly sure that's what you're talking about. And it was a small adjustment so let's hope that was it!
Also, because I know the opinions on these are the entirety of the bell-curve on here:
New Projectors with HID @ 5000k!
I admit, they aren't the most beautiful things out there, but the light output is incredible compared to the stockers!
I need to do the same to get an accurate mpg reading. I'll post up the results. But the gauge is always in the read barely, even when coasting downhill. Is that normal?
Your car is coming along nicely, I like the side markers and the projector lights (outer) what are the lights closer to the grill? Fogs?
Yeah to be honest I'm not sure either! I just finished 180 miles today from Asheville to Athens GA and the trans issue is largely gone! Crazy, huh? Only one very minor occurrence of surge - and it was over shortly. So I guess the adjustment worked.
Definitely only used 1/2 a tank to get here - so ~ 25.7MPG. @ avg of 75mpg
The lights closest to the grill on the bottom are the parking lights, and the upper is the high-beams. I freaking love them! The light output is incredible. Not as clean as projectors I have had in the past, but about 350% better than stock. And I got them on eBay for $120 shipped
(found a heck of a deal on them and won with the 1st and only bid)
Hopefully tomorrow in-between practice and heading back to Athens (hopefully! fingers crossed my scores were good enough). I think I'll attempt the timing cover seal whilst I'm at it. *gulp*
I can't tell if the trans is slipping/or hesitating. It is pretty old - 175K
Negative bromosexual - my gauge is only in the red on initial takeoff. Otherwise it's mostly halfway, or completely on the black end. Even doing 70mph, barely off the black end of the needle.
Stuttering and hesistation? Try this if you can http:// http://www.benzworld.org/forums/w124-e-ce-d-td-class/1231077-fuel-mixture-adjustment.html
I did it last night, and driving to an out of town dance competition (
) I noticed an increase in mpg, a pretty significant one considering I didn't even go that far and it was pretty noticable.
Got underneath the old girl and changed out the front flex disk. Thanks be to the forums for all the helpful info. I would have been largely f*cked without it.
Anywho onto the pictures -
New Lemfoerder unit, all shiny and pretty up in there
The old unit was banging around almost every shift, the bearings were so loose they were slopping around in there with only hand-force, and oh hey would you look at that. A gigantic crack which could have caused it to grenade and ruin my bellhousing.
Other than that, I'm narrowing down on the right trans setup for me - I'm about 95% satisfied with how it runs and it's all minutia from here on out.
Happy MB owner, for now
