MY new E320 Wagon
Is there a switch that locks the doors?
I think the right side speakers are blown, how do I repalce them or access them without breaking anything-especially the ones in the dash area.
thanks in advance
brett
You can lock or unlock all doors and tailgate/trunk(boot cap'n) by using the key in the driver's door, passenger's door or tailgate/trunk lock. You can also do the same by raising/lowering the lock knob on the driver's door or passenger's door, although the driver's door must be closed to do this.
Speakers in the dash are fairly easy to get to, but if your car has seen a lot of hot weather or sunlight on the dash, you are likely to break the small plastic trim piece covering the screws for the speaker grille, usually less than $8 for the pair. Be careful not to mar the dash when you are prying these little things out.
Temp display blackout is VERY common on these cars, you likely need the display unit itself. The problem here is cost, for what it costs to replace with a new unit you could buy an autodimming aftermarket mirror with the temp function built in. The display units run $300+ at the dealer. If you can tolerate a little risk, you can usually find one on eBay for around $60, just make sure it is the correct part (000 542 71 27 for Celsius and 000 542 72 27 for Fahrenheit).
Congrats on your new Benz! The TE is one of my favorite body styles.
-D
-D
