oil leak from the back of the engine
I have a oil leak coming from the back part of my engine. I'm not sure where its coming from. Hopefully on Monday i can get my mechanic to put in on the hoist. Also, for sure I know its oil, i'm not sure if its engine oil or transmission oil. I was able to dab some of the oil off the ground with paper towel just to verify. The appearance of the oil seamed very clean as is my engine oil. Suggestions would be appreciated. Also, when I opened the hood, I could hear fizzing noise, as if something was dripping onto the exhaust manifold.
I replaced my gasket last week and hey presto! no more oil leak.
I was able to get my car on the lift today. The culprit seems to be the valve cover gasket on the passenger side. The driver side shows no sign of a leak. I will have both gaskets done at the same time. Total cost is $200.
I was able to catch up to my regular mechanic on Saturday morning. I explained to him how i saw oil dripping from my car the previous week. Also, from my earlier postings, last Thursday I went to another independent garage just to get my car put on the lift. I was able to see a big wet spot of oil. That mechanic was actually able to get be to believe it was the valve cover gasket on the passenger side. His price was $175 to do one valve cover gasket and a extra $25 dollars if I wanted both done. Now getting back to my mechanic, who had previously did the valves and head work on my car. He took is light and he examined the engine, asking me which side the oil was coming from. After telling him the passenger's side he checked the valve cover gasket and said it was not leaking. On a my 400E there is a hose on the upper rear of the passenger side valve cover that is held in position by a self-tightening clamp. This was where my leak was coming from. After 10 minutes of finding a new clamp, everything was good to go. I've had my Mercedes for almost a year now, I'm learning alot not just about Mercedes but cars in general. The 1993 400E is definite keeper.
I have a 1990 300E 2.6. there is a leak from the front of the engine on the pass side. It looks like it the headgasket, leaking oil. Ive heard this is normal, and expensive to fix. Seeing as its on the outside, and the inner part of the gasket is fine, would it be safe to put something like a jb weld over the area that leaks?
dont want to start a new thread about a old topic.
