Bought 300TD with busted window mechanism
Old Mar 12, 2017 | 08:54 PM
oldspa's Avatar
W124 300TD, Hillman Imp historic racer
Just bought a 300TD 1994. My late father had several old Mercs the last being a 123.
Following in his footsteps and ended up with a 124.
Has a busted rear left window mechanism, common problem I understand. Going to fix it, looking at regulator / motor mechanisms on the internet, wondering if this assembly is the same unit on the estate and the saloon?
Many thanks,
Keith
Old Mar 13, 2017 | 09:32 AM
optimusprime m1's Avatar
W124 260E
Rear doors are cable operated , and mechanical fronts But take the door card off and check the wires in the door before they go to the window motor .I swaped one out only to find it was a bad connection in the end . And the one i fitted is slower than the original motor at lifing the glass up. Wedge the glass in the up position to hold it up .And on refitting , dont lock the retaining bolts up in the door untill the window is in the right position Try it up and down a few times then lock it up..And fit the membrain back on the door before you refit the door card or rain will get in the footwell .Most important is to remove battery leads .It will damage your hand if it operates if you in there ..
Old Mar 14, 2017 | 08:40 AM
oldspa's Avatar
Thanks, have ordered one now so will see how it goes..
Old Mar 14, 2017 | 10:45 AM
W124 260E
Any problems just let us know..
Old Apr 22, 2017 | 03:39 PM
oldspa's Avatar
Thanks, bought one off ebay and it went on like a dream. So much easier to replace than the ones on our B5.5 Passat
Old Apr 23, 2017 | 08:22 AM
W124 260E
oldspa good to hear it ,but the backs are a lot more complicated they run with cables and not that easy to fix ,.I will hve to do my rears at some time or other as they never last for ever . .
Old Apr 23, 2017 | 05:23 PM
oldspa's Avatar
It was a back that I replaced and it was straight forward. Don't think it took an hour and I'm a slow worker!!!
Old Apr 24, 2017 | 04:13 AM
W124 260E
oldspa was it electric or manual? My rears are operated by a motor and then a cable works the up and down parts ,instead of the metal arms .
