w124 e220 wont start...kindly help
Old Nov 18, 2017 | 10:34 AM
Kishan Gilbert's Avatar
w124 e220 facelift
Hi , My w124 e220 sedan facelift ,after filling petrol at gas station ( when the gauge was almost at empty ,but reserve had not come on) , i restarted the car ,the car switched on for few seconds and switched off automatically. this had never happened before . So i called up my mechanic on my phone & i was telling him about the issue. After a minute or so after few attempts , car started again and i drove it for a few kms and after i went over a speed bump , it stopped again. It refused to restart. So i called up my mechanic & he came down , checked the fuel pump, and he conncected a wire directly to the battery and then the car started. So he then plugged out and connected it to one of the fuses in the box and we drove down to the repair shop. no warning lights had come up . so we found that there was this green relay behind this battery terminal with a melted fuse & corroded electrodes. so after replacing the fuse the car came back alive. So after testing it for a day , they had put back all the panels removed and on the way it has been noted that the horn & the turn signals are not working. Now they have parked the car in the apartment and have left. And it is to be checked on monday morning. So if any body could throw light on what could have gone wrong it would be very helpful.
i have attached the pics for reference
melted fuse
Old Nov 19, 2017 | 03:52 AM
w124 e220 facelift
Originally Posted by Plutoe
That relay is used to actuate many things on many 124 cars, however my guess and without a VIN is that it actuates the intake manifold heater----bla bla
the relay after removing the fuse , we found corroded slots . but now the horn & indicators have failed to work, but the hazard light is working. what should i look out for ?
Old Jan 1, 2018 | 05:24 PM
redsn8k's Avatar
95 E320
I believe the relay you have provided pictures of and the description you gave of the location is for the fuel pump.
Old Jan 3, 2018 | 04:13 PM
Russell Ormerod's Avatar
not a merc
That is the fuel pump relay only. The fuse melted due to a poor contact at The fuse itself. Check the pump draw to be sure. 8 amps max!
Check the the fuses where he tapped power from, on a 124 don't look at the fuses check them for power on both sides with A GOOD 25w test lamp
Old Mar 1, 2018 | 10:06 AM
optimusprime m1's Avatar
W124 260E
Fuel relays dont have a fuse on the side like picture...Hot wire a car is just asking for problems .The relay in qyestion is a multi item relay it cover a few items .Look like a replacment is in wanted .
Old Mar 1, 2018 | 10:29 AM
W124 260E
This is the same multi use relay.
Old Mar 1, 2018 | 12:22 PM
w124 e220 facelift
i have replaced the relay now...hopefully i dont see it happen again...thank u
Old Mar 1, 2018 | 02:43 PM
W124 260E
Fine good luck ,.Nice to know its back to normal now..
