Rough running after top overhaul
Now the engine runs kinda rough, a noticeable amount of vibration that was not present before. Engine revs sometimes drops then comes back to normal, things improve a bit when engines warms up.
Could it be the valves were not seated properly?
No faults shown on the computer, wiring, vacuum lines seem to be in order.
Any ideas? Thanks.
But its seems some of the connectors of the wiring harness have started to break again.
But I recently had the car plugged into the computer, no faults showed up, isnt that enough to discount that it could be the wiring harness? I think any shorts/breaks in the wiring harness usually results in fault codes showing up in the computer.
Which specific parts of the harness should I check out?
Another thought - maybe you have dirty injectors.
Will have the injectors checked.
Thanks.
