Cold Start Injector
I bought the car from my father-in-law who chased the same issue for years with Mercedes mechanics, to the tune of $1,000's.
Car kicks over immediately and dies, sometimes 2 or 3 times, then will finally catch if I hold the starter for 5-10 seconds.
Then the car runs poorly for 15-20 seconds and then settles down and runs completely normally.
Was researching the issue and found a number of sources pointing to the cold start injector. It's a fairly expensive part... over $300.
Looked though all the paperwork from my father-in-law and it seems to be the ONE thing Mercedes didn't replace.
So today, I went to a junk yard and found a couple of cars with the injector and got them both.
Came home, cleaned them up and was going to install, but I can't get the one off my car.
Has anyone replaced this part? The blue one?
It appears it needs a 5mm allen tool, but can't get anything in there except a long allen wrench which just bends when I try to turn it.
Has anyone replaced this, and if so, what tool was used to remove the original?
As you can probably see, I've made a mess of this bolt now. No idea how I'm going to get it off.
I actually replaced that unit, thinking it may have been the cause of my issues. No help.
I put in new plugs, wires, distributor/rotor ~ December, so that shouldn't be an issue.
And yes, it's the M104 with the dreaded biodegradable wiring harness. That's my next project - starting to try to figure out how to source the correct harness.
Gas cap seal is good, it hisses when I remove the cap to add fuel.
Vacuum leaks are the devil.
Also on other models they have a WUR or - warm up regulator that helps at cold starts but i dont think you have one on your set up do you ?.
The car run perfectly, idles like a rock ~700rpm, accelerates and decelerates perfectly and doesn't hesitate on acceleration.
I'm pretty sure my problem is that cold start injector, but I still can't figure out how to get it out.
