Cruise Control - Replaced Amplifier - New Issues
Old Apr 28, 2022 | 04:35 PM
300SE1993's Avatar
2012 S350 Bluetec, 2014 GLK250 Bluetec, 2026 E350 4Matic
Hello all! I was wondering if anybody experienced something similar to this. My cruise had been going out for a few months now. It would actuate fewer and fewer times, until finally it would not actuate at all any more. I was highly confident that a rebuilt unit (Programa) with the same part# and reusing the code key would solve the issue. Got it all reassembled, and when I started driving the ABS light came on. I stopped the car and reset all the fuses (I pulled the fuses for the dome lights while I was working). After restarting, the ABS was working again, but the cruise control did nothing except one time it came on briefly after a long delay. I tried multiple times after that and nothing. I tried searching but doesn't seem like anybody has quite experienced anything like this before. Any suggestions appreciated. 1992 300D 2.5 Cruis Amp PN 0055450532
Old Apr 29, 2022 | 12:09 PM
dolucasi's Avatar
190E 2.6L 1989, 190E 2.6L 1988, BMW 535dXdrive 2014, BMW 428i 2015
Not sure but the cruise control would be considered a sensitive circuit just like the ABS. I suspect they are on the same fuses, OVP etc.
Did the ABS light come on when the cruise control was also on?
If your CC amp is also in a similar location as in the W201's (inside cabin) they are very sturdy. Even though they fail now and then I would say the actuator at the throttle under the hood would be more of a suspect. Perhaps it is drawing too much current?
- Cheers!
Old Apr 29, 2022 | 03:34 PM
300SE1993's Avatar
- Cheers!
Thanks for the feedback. The ABS light came on and then I turned right back around to go check the fuses, so I didn't get far. I went for the amplifier because I read somewhere that's where 90% of the problems are, but looks like I am in the other 10%. I just ordered an actuator. Looks like it will be relatively easy to replace. At least when I am done, I will have basically a new cruise control system good for the next 30 years, I hope!
Old Apr 29, 2022 | 05:15 PM
dolucasi's Avatar
On another MB forum where I was active and for a while a moderator I hardly read about any CC amplifier issues on W201 or W124's. There was a little CC amp issue on W126's that I noticed.
Let's see where you land with the new actuator. With your model hopefully it is easier to replace than on a W201-2.6L. Sure seems like it is buried down there in the throttle area and would be a bit of a project to replace.
- Cheers!
Old May 1, 2022 | 03:30 PM
300SE1993's Avatar
- Cheers!
Looks like the acutator is right on top. The replacement should arrive tomorrow so I'll reply back with the results. Thanks for all the info!
Old May 4, 2022 | 05:48 PM
300SE1993's Avatar
SOLVED - The actuator installation solved my cruise issues. Works great now!
Old May 5, 2022 | 12:29 AM
dolucasi's Avatar
Very good to hear SE1993.
Happy motoring!
Old May 5, 2022 | 05:53 PM
incaico's Avatar
'92 500E (sold), '92 400E-'88 560SL, '17 S63 Cab, '66 230S-1962 220SE Cab-1958 220S
Part # please!
Old May 5, 2022 | 07:59 PM
300SE1993's Avatar
Originally Posted by incaico
Part # please!
You want to use the same part# that's on your car currently.
