cold start w124
Old Oct 19, 2004 | 05:10 AM
shams13's Avatar
E240 2004
cold start w124
can somebody locate me coolant temperature sensor on the M102 engine. I want to check a problem in my car that every morning it takes cranking of 5 seconds to start and after that it is perfect. May be coolant temperature sensor is a reason
regards
Old Oct 19, 2004 | 10:14 PM
Jer's Avatar
Jer
1994 E320
There are 3 temp sensors on the cylinder head: KE, climate control, and the gauge. The climate control sensor is a 2-pole connection with blue tape on the wire. The KE temp sensor is one of the 1-pole sensors.
It is possible the cold start valve is out of order. The valve is a blue device on the intake manifold. Remove it and crank the engine. Hold the valve over a cup and see if any fuel comes out.
Old Oct 20, 2004 | 02:03 AM
shams13's Avatar
E240 2004
out of 3 sensors which is the coolant temprature sensor that controls the cold start valve.
can you explian a little bit the procedure to check cold start valve
Old Oct 20, 2004 | 09:58 AM
Jer's Avatar
Jer
1994 E320
The sensor for the KE (fuel injection) is used for actuation of the cold start valve. I will look up the jobs tonight when I get home.
Old Oct 20, 2004 | 07:16 PM
Jer's Avatar
Jer
1994 E320
The job for testing the function of the cold start valve is very complicated and requires some special tools. I can still send it if you want. For now here are the pin assignments for the coolant temp. sensor.
Old Oct 21, 2004 | 07:12 AM
shams13's Avatar
E240 2004
i read on forums that to check this sensor, check the resistance between two connectors at different temperatures, i have the EHA table with me but whuch are the two connectors out of these four to check the resistance (Ohms)
Old Oct 21, 2004 | 08:21 PM
Jer's Avatar
Jer
1994 E320
You want to measure the pins for KE. They are shown in the pic.
