EHA Help needed
after doing that work the fuel pressure now holds around 40 psi when the engine is shutoff and maintains the 80 psi while running.
but I am still having the same issues as before and am beginning to think that its something to with the electrical because I just noticed that the eha valve connector was covered in oil so i tried to unplug it only to find that the car runs the same with it plugged in on not. I had also found the same thing with the idle switch on the throttle cable linkage, no matter if its pushed down or not or unplugged it just doesn't do anything.
if anyone with knowledge of this system can help me out it would be greatly appreciated and thank you
I'm guessing it will measure 0V (should be battery voltage). If so, get a new OVP from your mercedes dealer and not a URO one. They last about 10-15 years depending on many factors.
From your description of the issues prepare to be dealing with multiple issues.
Please just respond to these questions line item by line item.
(1) What is the rpms with the car idling in park with the warm engine.
(2) What is the rpms when you unplug the IACV connector as the warm engine is running
(3) Measure the voltage on the connector after it was unplugged (DC voltage)
(4) As the car is still running plug in the IACV connector and tell us what happened. Did the engine stall?
Cheers!
(1) Idle RPM in park is 800 (warm engine)
(2) The RPM when IACV is unplugged (warm engine) is 500
(3) When I measured voltage pin to pin, I got 0v. From ground to pin it doesn't get a good read, randomly fluctuates so I don't have a solid number.
(4) While running, when I plug the IACV connector back in the idle increases to 1000 RPM and stabilizes for a few moments before returning to 800rpm rough again.
Hope my answer's gave a better idea, Thank you!
But your readings suggest the ECU is alive and trying to regulate the idle to the best of it's capabiilty.
Does your CEL even work and is it lit up?
If not you need to try and read some error codes on your diagnostic port by the battery. You need an OBD-1 reader (if it is not built in, some models have it built in)
I would start by measuring your duty cycle at the X11 port pin 3 to pin 2. Read up on this and the possible error codes it may have. It should be cycling at ~50% duty cycle +/-5% every 1-2 seconds
