idles too high
Old Feb 25, 2005 | 12:08 AM
1991-300E's Avatar
1993 500SEL W140, 1998 C280 Sport, 1996 W140 S500 long
idles too high
hi guys i need some help with this one:
i recently bought a 190E wuth a 2.6 in it but lately the rev's stay too high on idle and even when i drive it. i can go up to 70 kmh (sometimes) without touching the accelerator, but it doesn't happen too often
here is the list of new parts since i got it:
new spark plugs
wires
rotor and cap
fuel pressure regulator
oxygen sensor
serpentine belt
the mixture of gas and air was adjusted and the problem didnt go away and since this car is a 5-speed it is really annoying because high rev's make it hard for shifting gears.
when this happens rpms go as high as 2100 and willnot go down for a while
but even when everything is "OK" the rpms go down slowly (when i rev it up to say 4000 and let go of the pedal they slooowly go down)
i'm sorry for the long post but this is really pissing me off
so if anyone has any suugestions please feel free to drom a line here
thanks
Old Feb 25, 2005 | 10:34 AM
Jer's Avatar
Jer
1994 E320
If you push the accelerator and the engine speed takes awhile to drop, the throttle cable or air plate might be sticking. Does the engine idle normally after it warms up?
Old Feb 26, 2005 | 06:37 PM
1991-300E's Avatar
well i will check that out but i doubt it
thanks for advice
Old Feb 14, 2012 | 07:58 PM
Cartagena's Avatar
Throttle cable was sticking in my 190E as well. It needed two $6 plastic connectors that were broken. No more high idle.
