Window regulator - before installation
Old Mar 17, 2005 | 05:34 PM
bingoldsby's Avatar
Before getting the door apart - can someone please tell me what size (diameter and length) the rivets are? I think 3/16 is the diameter, but can't find the length spec anywhere.
Thanks for the help - doing the job Saturday.
Brian - Yakima, WA
2000 E320
Old Jan 6, 2006 | 01:59 AM
cody's Avatar
2000 E320 Nice & Stock
Brian - Yakima, WA
2000 E320
I used 3/16 by 6mm or so.
Old Jan 6, 2006 | 10:52 AM
purplegrog's Avatar
2012 C250
If you buy the mercedes window regulator, it will come with all the rivets you'll need. It requires quite a bit of force though (since they're steel). I ended up using a c-clamp on the riveter to be able to get enough force for the core of the rivet to cut off.
Old Jan 7, 2006 | 12:41 AM
cody's Avatar
If you buy the mercedes regulator in California, you'll have the opportunity to buy the rivets for $1 each. I just bought them today. They're extra. I'll show you pics of the Mercedes rivets vs. plain old rivets later.
Old Jan 7, 2006 | 12:31 PM
purplegrog's Avatar
2012 C250
I stand corrected. rivets were extra for me too, except they were $.50 each (x4=$2.00). Total cost was $72.53 (incl. tax) from Ben's Workshop in Austin
Old Jan 7, 2006 | 02:16 PM
hadam's Avatar
2007 S-550, 2001 E-430 & 1997 E-420
Aluminum Revits
With my small rivet gun I can not apply enough force to install MB stainless steel rivets.
I went to Home Depot and got same size Aluminum revits [Qty 50 for $4.00].
It was so easy to install aluminum revits. Alumninu revits are as strong as MB SS revits. Windows stay find and no noise or any other problem.
Don't waist you $$ and time, go and get aluminum revit.
Old Jan 7, 2006 | 05:38 PM
cody's Avatar
$143 from Silver Star Mercedes in Westlake
Old Jan 8, 2006 | 01:24 AM
Gomez153's Avatar
97 e320
i bought mines on ebay for 40.00 bucks shipped and spent another 30.00 on a rivet gun and rivets from home depot = 70.00 bucks a cup of coffee and 2 hours easy as hell i have pictures on how to do it .
Old Jan 8, 2006 | 09:09 AM
purplegrog's Avatar
2012 C250
Everyone talks about how easy this repair is, and for the most part it is, but FYI for those who don't know: when I drilled out the rivets, I had a hell of a time doing it. other than that the job was easy as pie.
