95 E420, where's the obd2 port for cels?
Old Apr 12, 2005 | 03:15 PM
all stock's Avatar
The dealership told me it's OBD2, even though it's a '95. So I'm looking for the OBD2 port for the scanner and I can't find it under the dash. All I CAN find is 2 diagnostic ports under the passenger side hood near the firewall.
One port has an 8 hole pin out with a small button and a light. The 8 holes do not fit the actron obd2 scanner, the are aligned in a straight line.
The other looks like a Formula wire harness connector, it's circular not 8 pronged like the normal OBD2 connectors I've seen. However, this one is located near the ECU (which in located in this battery looking thing under the hood).
Anyhow, my question is where is my OBD2 port so I can plug the scanner in? I'd like to check my code for free instead of paying a stealership.
Thanks in advance.
Old Apr 12, 2005 | 03:52 PM
Fast55's Avatar
'06 E55, '05 SLK55, a few others
It's not OBDII, the dealer is
Old Apr 12, 2005 | 04:15 PM
E-Klasse's Avatar
W205 C300
That is a W124 E-Class if it is a 95.
Old Apr 13, 2005 | 01:45 AM
all stock's Avatar
So the only way to check for CELs is thru the dealer or dealer diagnostic tool? There's not service connector to short, huh?
Hondas are so much easier...
Old Apr 14, 2005 | 05:25 AM
Petmerctech's Avatar
OBD2 was not mandatory until 1996.
Old Apr 14, 2005 | 05:47 AM
all stock's Avatar
neither was the secondary O2 sensor.
Old Apr 14, 2005 | 10:51 PM
duckwood's Avatar
Take it to Autozone, they read codes for free, and may be familiar with the location.
Old Apr 15, 2005 | 01:12 AM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
OBD-II wasn't on 95's til all cars have them on 96 and newer. You can try to find it but it usually under the driver dash, you should have a flap door and the port is there but if you don't see a flap, then you don't have a OBD-II on your car.
Old Oct 29, 2012 | 09:23 PM
GuamE320's Avatar
1996 MB E320
Awesome mines a 1996 so it should be OBDII compliant great news!
