Check Engine Light
Old Nov 2, 2010 | 10:25 AM
taidom88's Avatar
Mercedes Benz E320
Check Engine Light
I also have two "check engine" warnings on my display. One is the amber light on the lower right display, the other in the center - says " check engine & engine electronics". I have not driven my car for several months. Now that I started to drive it again, it started fine and initially drove fine, then after 30 minutes I was at a red light and the car started slightly shaking while idling only (and the check engine light came on but not the center light with the engine electronics), acceleration and driving are fine. Ten minutes later, I reached my destination and turned the car off. When I turned the car back on, the center engine electronics light came on and the right side check engine light is still on but the car was running fine again without any problems during idling. So now the car is running good but how do I get the 2 check engine lights off. Thanks.
Old Nov 2, 2010 | 12:56 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Begin by checking (or have checked) the OBD . If you buy a OBD II scanner to DIY, you can post the error codes out here for help. Generally, it requires a little interpretation.
A scanner can clear the check engine light but if the problem still exists it will just come back on. Better to sort out the problem and fix it.
Old Nov 2, 2010 | 01:59 PM
ohlord's Avatar
Start
with the simple stuff.
If you just filled the tank after not using the car make sure the gas cap is on properly.
take it off put it back click it shut
all with the engine off
If it was sitting for a long period make sure you charge the battery.
If that don't clear the codes
Do as above and get the codes and post em here
some autozones and the like scan for free
if the remedies above don't clear them and nobody around does it free get a scanner at harborfreight like item 94169
easy to use and worth its weight in gold if it avoids even one trip to a shop
Old Nov 2, 2010 | 03:02 PM
Lancelot's Avatar
'01 W210 E320 CDI
Off topic:
I once drove my company Toyota with a CEL light on to the shop, and told the guy at the counter: "My car says Check Engine, so I did and the Engine is still in there so that can't be the problem!"
Good luck with the codes though...
Old Nov 2, 2010 | 03:07 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
I took out my hockey stick and checked the engine when it said to. It never gave me a bother again. I live sometime in Canada!!!!
Old Oct 29, 2012 | 08:55 PM
GuamE320's Avatar
1996 MB E320
I have a 1996 E320 with the same issues as the OP where is the OBDII port on this car? Thanks
Old Oct 29, 2012 | 09:16 PM
illest's Avatar
w210 AMG or S213
under the dash on the drivers side.
Old Oct 30, 2012 | 12:10 AM
GuamE320's Avatar
1996 MB E320
