Lights bulb questions
#51
1 Post
AMG E55, Stage 1, Strait Pipe from Primary Cats
This site has all the non DOT German bulbs halogens and hid's..Socal Website
Hey Guys,
This site in SoCal has all the non DOT German bulbs halogens and hid's..
http://suvlights.com/
here is a sample
H1's
PHILIPS - Vision Plus +50% ECE 55W $26 / Pair
OSRAM - Silverstar +50% ECE 55W $12 / Each
NARVA - Range Power / PHILIPS - Premium +30% (DOT/ECE ) 55W $10 / Each
NARVA / PHILIPS Original Equipment (DOT/ECE ) 55W $6 / Each
NARVA / PHILIPS Rally 100W $8 / Each
NARVA / PHILIPS RALLY 130W $10 / Each
Super White / Blue
SYLVANIA - Silverstar 55W $18 / Each
PHILIPS - Crystal Vision 4000K 55W $46 / Pair
PHILIPS - Diamond Vision 5000K 55W $60 / Pair
NARVA - Range Power Blue /PHILIPS Blue Vision 3600K
DOT/ECE 55W $15 / Each
HIPER IND. - Plazma Xenon 4100K 100W $25 / Pair
Gold / Yellow
NARVA / PHILIPS - Gold 55W $15 / Each
NARVA / PHILIPS - Rally Gold 85W $18 / Each
NARVA / PHILIPS - Rally Gold 110W $20 / Each
WORLDLIGHT - Rally Gold 100W $15 / Each
All Weather / Season (slightly less yellow than Gold)
PHILIPS - Yellow Star/NARVA Azzurro ECE 55W $30 / Pair
here is a sample
H1's
Super White / Blue
Gold / Yellow
#52
2007 S-550, 2001 E-430 & 1997 E-420
Philips Diamond Vision 5000K H1
I had contact the http://suvlights.com/ but he did not have Philips Diamond Vision 5000K H1. They got Philips Crystall Vision 4300K H1, but not Diamond.
They also told me that Diamond is too blue, but it is not true. Diamond is white like my Xenon and match great. There is very very little tint of blue, that hard to notice.
If you have clear lense fog light then you might get little more blue tint.
#53
98 W210 Advantgarde
#54
Here's my ride with the OEM Xenons, Polarg B1 Hybrid Hyper White City Light 8W for the parking lights, and Philips Diamond Vision H1 foglights. The first set of two Polarg bulbs had one yellowish and one white bulb, so I ordered a second set, which had the same problem! Anyway, I ended up with two good bulbs. Of course, having snapped off one of the prongs of each bad bulb, I was unable to return them.
Pre and post-mods:
Pre and post-mods:
#55
1 Post
1998 E320 / 1992 LandCruiser / Project Car E30, 91, 318I
should get:
Fog Lights: Phillips Diamond Visions
Hi Beams: Sylvania Silverstar H7
Parking Lights (also referred to a City Lights?): Polarg B1 Hybrid Hyper White City Light 8W.
they don't make Polarg B1 Hybrid Hyper White bulb anymore. is there any bulb out there that is close to Polarg? (not LED)
#59
2000 E430 Sport
Led Lights/city Lights
If you want to do the mod read this. Get rid of the yellow lights.
https://mbworld.org/forums/showthrea...ght=led+lights
#61
Anyone tried the Osram bulbs?
I ordered a "set" of "Hilite" Xenon-style bulbs for my 1999 E 300 TD.
http://www.xenonlightshid.com/
However, a "set" conists of hi and lo beams + foglights. So now I have a weird effect of Xenon-style outer lamps and yellow inner "city lights."
I am a little uncomfortable going with the higher wattage of the Polargs that seem to have consensus approval on this site. Several people, on this thread and on another MB site, have expressed disappointment with the Philips H6W.
Does anyone know anything about the Osram Super Cool bulbs? They are available through:
http://www.redgriffin.co.uk/products.asp?cat=79
Any comments welcome...
#63
check out my post, above.
Dude, check out my post, above. You can get a set of Xenon-style bulbs for the outer lo and hi-beams, plus fog lights, for $50 (incl. shipping and Calif tax) from: http://www.xenonlightshid.com/
Shipping is just about instantaneous. If you order today (based on the L.A. residence), you should have them by Friday.
The problem is with the inner "city lights." These are the lights that run as parking lights and are on all the time. There are H6W, which are difficult to get in Xenon-style. Philips and Osram have H6Ws, which can be purchased through various sites in the U.K. As noted, folks who have purchased the Philips bulbs have been dissatisfied with teh output, which still looks a bit yellowish.
The Polargs are 8 watts, as opposed to the 6 watt H6Ws. Obviously, the electrical system was designed for 6 watt, so buying 8 watt bulbs is not, so to say, Good Housekeeping approved. You have to file off one of teh prongs to make them fit. Some peopole have apparently purchased them and reported that the difference is not significant enough to trip any warning lamp. The company with the Polargs is located in Reseda, which may be close enough for you to stop by and chat with the proprietor. I just ordered a set myself and I'll give it a shot.
#64
Polarg Results
I got the Polargs and installed them in my 99 E300. Even though higher wattage, they are not as bright as the OEM bulbs. (Not a big deal, since they are not used to provide light for the driver to see with.) They are not quite as yellow as the OEMs, but they are definitely yellowish. A substantial improvement, but not ideal. It took me a good hour to remove the prongs, and file them down and install. (Note that there is not a lot of space to remove light cover on passenger-side and wiggle on old fixture and install new; this can take some time.)
No error message re higher wattage.
#65
1 Post
C55AMG W203; 330i E90
just tried Philips Diamond Vision 5000K H7 for fog , it matches well with the 6200K D2S too. !
more photos:
https://mbworld.org/forums/showpost....1&postcount=88
more photos:
#66
1 Post
No blue tint.
#67
Guys, any further updates on the Polargs? I've just had one of the yellow OEM bulbs burn out and was going to order these, but wondering if anyone found the perfect city light replacement yet?
#69
Philips Diamond H1
Finally after amost 2 year I have one burn out Fog light Philips Diamond H1 bulb.
Do any one know where I can get replacement.
I did search on web and ebay but no luck.
#70
96' E320
Has anyone tried the LED's? I cant stand that cheap blue look, its so not mercedes. The Polarg city lights look way too blue and not right at all. If anyone has some pic's of the LED's we'd love to see it. thanks
#71
98 W210 Advantgarde
To be fair, since I was one of the the people recommending the Polargs originally, they were one of the better solutons at the time before LEDs became popular and they tend to be whiter in facelifted W210's due to the differences in design of the light housings - the pre-facelift ones have a lot of silver-grey material behind the lense that gets picked up by the light. The Polargs are perfectly white behind W203 and other newer lights.
#73
Anyone know if the following LED lights will need a resistor to prevent the deahs warning ?
http://www.ultraleds.co.uk/uh6ww-bax...de-p-1186.html
