DIY Brake Job
I got the part pricing from dealer as following.
Parts Pricing with rotor
Front Brake quantity each Total
Brake Pads 1 $91.96 $91.96
Brake Sensors 2 $5.76 $11.52
Rotor 2 $96.80 $193.60
Rear Brake
Brake Pads 1 $66.04 $66.04
Rotor 2 $64.08 $128.16
sub Total $502.80
Tax $37.71
Total $540.51
Do any one know if I can find the thread where I can learn how to do this brake job by my self ? I have never done one.
What is the wheel seal for front wheel bearing ??
All feed back will be appreciated.
https://mbworld.org/forums/e-class-w210/107227-okay-brake-job.html
https://mbworld.org/forums/showthrea...ghlight=brakes
There is nothing to it.
After that, use the search feature on this Forum, read everything you can... after that git r done.
Is any one know what is wheel seal and why this need to be serviced? One of the local German Autos is telling me that they need to check wheel bearing and lubricate them and install new wheel seal.
I don't understand why I need to check wheel seal and lubricate the bearings??
As far as the wheel seals, you don't need them unless you're going to replace or repack (grease) the front wheel bearings. At 112K on your E I would definitely be doing one or the other (probably repacking).
MBZ probably has it's own required grease as well, but the mobil1 synthetic grease is excellent.
Take care and enjoy the ride,
Greg
I check on different web sites for parts pricing and got front brake pads, rotos, sensor and wheel seal with free shipping for $250.
Which vendor parts are closed to MB OEM parts. For example for Rotor Zimmerman or Brembo. For front pads Textar, ATE, PBR or Pagid.
Which vendor should I use for Rotor and Brake Pads?
Any feed back will be appreciated. Thanks again for all the good information.
If you do the rear brakes spend the extra $$ to get drilled rotors. I think MB somewhat mispecced the rear rotors so they have a tendency to warp.
http://www.epsparts.com/category/chassisnumbertable/
There are lots of retailers of these parts (see above post). Ironically, before I ordered mine, I came upon a guy selling the entire package since he had sold the car he purchased them for prior to installation.
So, while I would have liked to have the cool cross-drilled rotors, I opted for the plain OEM version, since I have the factory alloys anyway. As for pads, reasonable minds will differ (just run a search!) but I am very happy with the Textar (yellow box) that I bought. I got the whole shebang (two rotors, two sensors, 4 packs of brake pad goo, and the Textar pads) for $140 including shipping cost.
And, if you have not gotten this by now, it is really easy. Read the post here, only do one side at a time, or use a digital camera if you need to remember how it came apart.
Whole job took about 45 minutes from start to finish.
Textar Brake pads (Yellow Box)
Zimmerman Rotor (Regular and not cross drill hole one)
Pex brake pad sensors
Brake Anti-squeal Paste Single Application
Wheel Seal for front wheels
Total Cost with shipping came out to be $227.64
Qty Brand Sku Description Retail Price Core Total
2.00 AAA:PEX N1030-26105 Brake Pad Sensor 3.70 1.76 0.00 3.52
2.00 AAA: K8010-53273 Wheel Seal 14.50 4.79 0.00 9.58
2.00 AAA:ZIM N1000-66184 Brake Disc 80.00 61.14 0.00 122.28
1.00 AAA:TEX N1010-104443 Brake Pad Set 76.00 67.87 0.00 67.87
4.00 AAA:OES N1005-125270 Brake Anti-squeal Paste Single Application 2.00 1.76 0.00 7.04
Core Charges: 0.00
Subtotal: 210.29
Shipping - UPG: 0.00
Total Weight ( 40.14 pounds ):
CA residents pay 8.25 %: 17.35
Order Total: 227.64
Any comments or feed back ??
Thanks a lot for all your help.
I didn't see the seals on your list, did you decide not to check the wheel bearings? If you want to pull and check them you will need new seals, and at your mileage I'd definitely be examining and repacking them at the least.
Good luck and enjoy the work!
Greg
It took us about 2 hours to remove old rotors and brake pads and install new rotors and brake pads.
Zimmerman Rotors and Textar [Yellow Box] brake pads.
Local MB dealer quote was $700
Local German Autos wanted $625
Another local shop wanted $550
DYI with help of friend was $290. Parts $230 and paid friend $60. My friend own a shop. So it was easier for me to use his lift and tools. My friend did 90% of the work.
You all save me at least $250. Thank you for great information on this forum.
Some notes from DIY rotor/brake job.
Front rotors were frozen. We put on it WD40 and 4-5 bang with hammer. That the part took most time.
Forgot to release the air pocket from brake lines. We did on each brake, remove the boots and did little pressure release and then brake works great.
http://www.importedcarparts.com/
Great price and good service. Thank you for recommending to me to buy parts from them. DHL ground delivery only took 2 days.
I am very
. This was my first DIY job on 97 E420.
Thank You!!
