Harmonic Bal recall - Anyone still waiting?
Old Dec 12, 2005 | 02:51 AM
  #76
enzo430S's Avatar
MB E430 Sport
I tried three times to find the part number but I still can't see it.
Where am I suppose to look??
Old Dec 12, 2005 | 09:42 AM
  #77
MG's Avatar
MG
Veteran: Army
1998 E430; 2007 Porsche 911 C4S Cabriolet; 2011 Expedition EL Limited; 2014 E350 Estate
do you know where the HB is?
If yes, the part number is on the outside rim of the HB between the belt and the engine block. It is nearly impossible to see from the front side of the belt. I had to lift the black engine hood off of the V8 to look straight down behind the belt.
If you can see white numbers (degree markings) then you are in the right place, you just have to wait until the HB stops with the part number facing up. Took me three checks before it was in the right position.
Old Dec 12, 2005 | 01:41 PM
  #78
enzo430S's Avatar
MB E430 Sport
Thanks. I think I'm looking in the right place. I'll keep checking.
Old Dec 12, 2005 | 03:30 PM
  #79
jrsalesco's Avatar
2004 E55
ok, i took the time to read all replies, but im still confused. i own a 2000 CLK430, roughly around 109k miles on it. the last time i took my vehicle in the service advisor did mention that there was a recall for the HB on my vehicle, they inspect it and said it was fine, but... if theres a recall on a certain part, doesnt that mean that regardless if its fine or not, it should be replaced anyways right? because my vehicle does fall in category. also is all p/n for the HB different? if its not, there no need for me to look for it since some people posted here on the forums for w208s. thanks in advance !
Old Dec 13, 2005 | 12:25 PM
  #80
spoothead's Avatar
2000 E430
Well, add me to the list. I also got my letter last Friday 12/9. I guess they sent out a big batch.
Old Dec 13, 2005 | 12:36 PM
  #81
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Yes , demand that it gets replaced.
Old Dec 13, 2005 | 03:23 PM
  #82
MikeyE430's Avatar
2010 E63 AMG, 2000 E430 Sport, Dodge Charger SRT8
Took my car in today for HB recall. They say mine is OK. HOWEVER, found that poly V-belt was split down the middle and replaced it to the tune of $146 including labor and part. Geezus.........
Old Dec 13, 2005 | 03:31 PM
  #83
MG's Avatar
MG
Veteran: Army
HB inspection today said that it needed to be replaced. Hour later it was all done.
Old Dec 13, 2005 | 10:27 PM
  #84
tomscia's Avatar
1998 E320 Sedan
I finally got my notice last week. Thanks, Tom
Old Dec 13, 2005 | 10:45 PM
  #85
velvet fog's Avatar
05 SL500, 02 BMW Z3 (Mrs. VF), 05 FJR1300, 91 ZX-11
Gettin mine replaced on Thursday. Only a one day wait for an appointment.
Old Jan 1, 2006 | 03:58 PM
  #86
eyedol911's Avatar
E320 2000
Still waiting
2000 E320 and I spoke to service advisor twice, the VIN, engine, part number are all in there, but still insist they need a recall/serivce letter from MB.
Still waiting...
Old Jan 2, 2006 | 02:56 AM
  #87
Howellja's Avatar
CLK, R350
Does this apply to E55's?
Does this recall apply to a 2000 E55 AMG?
Old Jan 3, 2006 | 12:27 PM
  #88
MikeyE430's Avatar
Results
Tech at dealer determined my HB was not affected. HOWEVER, they found that a 2 ft. section of my drive belt was split down the middle. About $150 parts/labor to replace. Glad they caught it before it broke on me.
Old Feb 12, 2006 | 02:52 AM
  #89
The Kingfish's Avatar
The harmonic balancer on my '99 CLK320 gave out on me a few months after the warranty ran out and I had to shell out over $2,100.00 to have it and the parts it took with it replaced. About a year later the car was totaled and so I went and bought a '00 CLK to replace it. Last December I got the recall notice for the '00 and had it checked out, it was fine. This is where the story gets real good. I told the service rep about the problem I had with my '99 and showed him the invoice for the repair and he says I should be able to get a refund from M-B for the money. It took two months but I just got a check in the mail for the full amount. Can't believe it actually happened so thank you M-B.
