Broken antenna on 2000 E430, looking for a fix
Old Sep 26, 2005 | 09:13 PM
King320's Avatar
03 C32 AMG
Hey 210 guys...
My father's E430's antenna broke. Im referring to the rubber 1.5 inch antenna on the back center of the roof. The rubber basically weathered and cracked and eventually fell off, so now the metal antenna itself is exposed and it looks awful. Anyone else have this problem? sorry i dont have a pic, the car is in TN. The dealer wants $500 to put a new one on, does anyone have an easier fix/upgrade for the problem? Thanks
Old Sep 26, 2005 | 09:20 PM
King320's Avatar
03 C32 AMG
found a pic on ebay
Here's what im talking about, the black rubber piece came off...
Attached Thumbnails Broken antenna on 2000 E430, looking for a fix-antenna.jpg
Old Sep 28, 2005 | 02:36 PM
spoothead's Avatar
2000 E430
Same thing happened to me. To fix it I went to the dealer and got a replacement rubber piece for a C-class. You can remove the cover for your broken antenna, I think with a hex wrench. The C-class piece is similar to but not exactly the same as the E-class part so I had to trim the bottom (carefully!) with a razor blade as it was to fat to fit all the way in the cover. Once you get a good fit just re-install the cover and you can't tell the difference. Hope this helps.
BTW the part # is 202-827-00-31 , description is CAP. Cost me 8.13.
Old Sep 28, 2005 | 03:47 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
the 202 stub does not fit properly and does not end up being waterproof.
greetingz,
Old Feb 26, 2011 | 02:02 PM
suntubi's Avatar
e320 2000
how about the mast replacement?
anyone have a low cost idea to replace the mast itself? Darn vandals!
Old Feb 26, 2011 | 03:06 PM
dylokjai's Avatar
00_e430_sport
I had to replace mine last weekend...i got the rubber antenna piece from
https://www.autohausaz.com/search/pr...=2108270031KIT
Old Feb 26, 2011 | 03:41 PM
raymond g-'s Avatar
99 E320
I had to replace mine last weekend...i got the rubber antenna piece from https://www.autohausaz.com/search/pr...=2108270031KIT
that's the competitive price for the cover, gasket and antenna.
for folks looking for cheaper, you can browse the forums where some of the
most frugal have successfully used the cap off a ballpoint pen. threads created
identifying which specific pen might have just the right diameter cap.
but i feel that is the ultimate in penny pinching and it's like taping your eyeglasses
together with duct tape or something. bleh
Old Feb 26, 2011 | 04:14 PM
ohlord's Avatar
Low cost
diy is on www.benzworld.org w210 section.
Don't know how involved it is as I have never had one broked off.
Old May 1, 2012 | 11:11 PM
atomicar's Avatar
box with 4 wheels & '01 E320
I have 2001 e320 that has broken antenna. I found a plastic tool handle that fits almost perfectly. Use tiny amount to glue the antenna to the base old antenna base. Right size plastic pens work also.
Old May 2, 2012 | 09:29 AM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
I bought a new painted cap from the dealer and the tech (who was doing other things at the time) put it on for no charge. That cost a little over $200, way too much of course!
Old May 3, 2012 | 01:51 PM
Figuero's Avatar
2002 E430 4MATIC
If I'm not mistaken that is the antenna for the analog based SOS system and isn't used for anything anymore. Perhaps if you use the old car phone interface it might be functional - but I think it's just for the obsolete analog signal.
Old May 3, 2012 | 04:11 PM
Musikmann's Avatar
I think you're correct Figuero. I know it's the antenna for the TeleAid system. I use the bluetooth puck and have a Motorola cradle and I'm pretty sure it works with the phone feature also.
Old May 3, 2012 | 08:04 PM
01BlackE320's Avatar
01 E320
Where is the radio antenna on our vehicles?
Old May 3, 2012 | 10:32 PM
atomicar's Avatar
I guess radio "antenna" itself is part of rear defroster wiring, but I could be wrong.
Old May 4, 2012 | 03:17 AM
raymond g-'s Avatar
99 E320
yup...
Attached Thumbnails Broken antenna on 2000 E430, looking for a fix-clip1.jpg
Old May 4, 2012 | 09:34 AM
Musikmann's Avatar
Thanks raymond-
Old May 4, 2012 | 06:20 PM
01 E320
An antenna for the worthless SOO system? I wouldnt invest a penny. Mine just has the wire sticking out
Old May 4, 2012 | 08:02 PM
raymond g-'s Avatar
99 E320
oh come on. you own a benz, a fine ride. would you go out with Kate
Upton and not brush your teeth or put on clean underwear?
Old May 4, 2012 | 09:02 PM
01 E320
well I did put in a new Kenwood Stereo and spent an hour restoring my headlight lenses this past weekend. I show the love
Old May 4, 2012 | 09:17 PM
raymond g-'s Avatar
99 E320
jest laughing with you...not at you. head unit upgrade is what i'm moving to next.
